Dawn Power Disolver
shadow85
This stuff is just awesome. It took out all the black spots on my microfiber that nothing will take out. Use as needed and there's no real set time as it seems to go to work on contact. Rinse well.
Note of caution, this stuff smells toxic!
Wear some gloves or it will eat your skin. Great on pads also.
Can this be used as a replacement for Snappy Clean or do you guys use it to pre-treat pads, before putting them in a bucket of Snappy?
spray onto pad. let it sit for 5-10 minutes. massage under running water. squeeze and shake out all the water as much as possible. done (i lay my pads on the grit guard to dry).
I only use them as a last resort as they smell so bad. A little goes a long way. Anything more, you will need a gas mask.
Excellant pad cleaner. Hand wash. Use in combination with Dawn Dish Washing Det. Rub in with thumbs. Rinse well. Pads wil be like new.
