So let me start of by saying blackfire wet diamond is a good product. I used it by hand and I recently purchased a Harbor Freight DA and got some Black and blue pads online with a 5inch backing. Am I doing something wrong or do I have the wrong impression, I don't see much difference if any when I used the DA with blackfire on the hood and didn't used anything else on the rest of the car. I even only did half the hood. I used a 3-4 speed setting and watch the videos on how to use it, the 6 pass style and slowly working it in. Any advice or tips? I'm not trying to do any swirl mark correction but i thought with the machine and heat it will produce a better shine/gloss? Should i change product?
tested it on a 2010 civic and 2005 rav 4.
Why you didn't see much of a difference with the DA vs. Hand
BLACKFIRE Wet Diamond All Finish Paint Protection is designed to produce maximum results by hand or machine. It is a high-tech, tri-polymer
sealant that leaves a very thin, very slick, extremely-protective film on your paint. This is the job of paint
sealants , waxes and coatings. Wet Diamond is among the best.
Because you are leaving a protective layer (film) behind, there is no real need to work it into the paint or make slow over lapping passes. Set your polisher on speed 3-4 and spread a nice, even and thin coat over the surface. Let it haze, and wipe off. Using your polisher in this manner will save you a lot of time and ensure even coverage.
So when does the DA make a difference?
While the DA will save time (and effort) when applying a wax, sealant or coating, it will really shine when using abrasive machine
polishes. Polishes are used to smooth away swirl marks and light scratches, while also resurfacing the microscopic wear and tear on your paint/clear coat. Because
polishes require friction, the DA will really shine. 113 orbits per second by machine + rotation, maybe 3 by hand)
