I have an 87 Buick with single stage black laquer that is 22+ years old and is in excellent condition. Aside from a few paint chips, minor scratches, and swirl marks, she shines like new.
I have been trying different approaches to "cleaning" up the swirls and light scratches.
I've tried OTC Mequiars polish and wax(Deep Crystal) by hand, Meguiar's #09 Swirl Remover with #7 Show Car Glaze and #26 Hi-Tech Wax. These combinations all left a "haze" after the waxing step both by hand and Cyclo
(Green & White pads).
I recently picked up a sample kit from detailking-dot-com that included their Spyder Web Glaze, Foam Pad Polishing Gel, and the Cherry Wet Wax. I applied the Spyder glaze with a yellow pad, Polishing gel with the green pad, and finished up with the wax and the white pad. Three coats of wax on the top surfaces and two on the sides.
The finish looks awesome....until you run your hand accross it and it leaves a fresh set of "fine" scratches....Am I doing something wrong?
From my past experience with clear coats and newer cars, after a good waxing you can run your hand accross the surface and worst case you get a smudge that wipes off? Is the "wet wax" just that, or is it softer than some of the other waxes?
I'm at a loss. Any advice would be appreciated.
Thanks.
Thanks.
