imported_Tom
As Doug posted, the Cyclo does morph when you take off the rubber backing pads and put on the quick release adapter. I believe that he mentioned the ves upgrade was not that critical when one changes to the snap adapter and he is correct.
My machine with the adapters and double pads is 100% vibration free, wierd really, you hear the motor running, see the pads turning but no other sensation that you are holding a d/a-so smooth it is really wierd.
Now to Doug's comments about being able to correct with this machine; again he is absolutely correct;
http://www.betsy-tom.smugmug.com/
here you will see some pics, they don't do justice to what I was able to accomplish using the convered Cyclo, astounding results. The before pics were taken after I spent a great deal of time using the pc, honestly I was not able to accomplish a whole lot-technique perhaps?
The chemicals I used were the same as with the pc, Mez Intensive followed by Griot's Machine Polish 3, then the Klasse twins X's three.
If you have a Cyclo do invest in the quick adapters and double pads.
