Customizers.....List your mods here........
Since this a customizing forum, I am interested to know what kind of modifications you have made to your cars (and trucks).......
And how much you've spent on after-market mod's......(although its none of my business!):D
Here goes:
17� Motegi MR7 Chrome Wheels
BFGoodrich Comp T/A 50 Series
Custom Painted Engine Bay
20% 3M Window Tint
Reflective Concepts Overlays
Wheel-Skins Leather Steering Cover
DynoMax Super-Turbo Exhaust
Audiobahn Bandpass 10� Sub
Removed Resonator / U-bend
Audiobahn Power Amplifier
Buick Strut Tower Braces
4 Audiobahn Door Speakers
Custom Red / Yellow Loom (by Pam!)
Street Scenes Speed Grills
Streetglow Headlight Strobes
STB & Fender Brace Graphics
De-Badged
Painted Calipers & Rotors
Brushed Alum Engine Cover Overlays
Removed UnderHood Pad
Perfect-Fit Hood Protector / Deflector
Sylvania SilverStar SuperWhites
Custom Flames
Lotek Pods, AutoMeter Gauges
Acura Cold Air Intake / K&N Cone
Stainless Steel Exhaust Heat Shield
Lexan Intake Heat Shield
Lloyd Embroidered Trunk Mat
MDM Deck Mat & Custom Plexi GT
I've spent about $2400. My wife has bought me about $800 in mods for gifts (Christmas, B-day, Father's Day!)...
Total $3200......
Not too bad for a hobby. I know a lot of guys that spend that much on a set of golf clubs!
Will I ever get that back?......NO.....but it's worth it to me for the fun of MODDING!
1990 Accord LX
Engine:
AEM cold air intake
AEM tru-power pulleys
DC Sports ceramic 4-2-1 header
EX ECU (no top speed limiter!)
Custom 2.25" exhaust w/Catgo high flow cat and a Vortec turbo muffler (very quiet at cruising speeds, nice roar at full throttle)
Wheels & tires
15 x 6.5 Konig Caffienes
Panther (made by BF Goodrich) 195/60 15s
Suspension:
Tenzo front and rear upper strut bars
Suspension Techiniques front anti-roll bar
Exterior:
Shaved emblems
Clear corners and bumpers-corners done JDM style with amber bulbs (see attached pic)
Silverstar 9006-9005 conversion
Sound system:
Sony head unit (cassette-got it about 5 years ago and I've got tons of tapes)
Kenwood KAC-848 4 x 50w amp
JBL-GTO-602 speakers in the doors
Kicker Impulse 6.5s in the rear deck
Miscellaneous:
Tinted windows
Sidewinder alarm
Cost? I don't know, a lot more than the car is worth.
'92 Eagle Talon TSi AWD:
  • Custom Spearco 221-B FMIC and piping (filter relocated to fender well)
  • 3" turbo back exhaust.
  • TRE-ported 2G exhaust manifold
  • TRE-ported 2G O2 sensor housing
  • 2G throttle body elbow
  • TRE-ported 16G turbo (no clip); 34-mm wastegate valve installed to prevent boost creep
  • Autronic stand-alone fuel computer
  • J&S Safeguard (not yet installed)
  • Aftermarket brake pads (Metal Matrix??? I think)
  • Upgraded suspension: Koni front/GAB rear; Eibach Pro-kit springs . . . I also have a set of Ground Control coil-overs sitting in the garage that I haven't installed yet (includes springs, but will use the Koni/GAB struts I already have).
  • Dunlop SP8000 "fair weather" tires
  • Gauges
    - White-faced gauge conversion
    - center-vent mount holds two gauges, currently VDO 0-30 psi boost and AutoMeter A/F, but I have two new white-faced gauges from Westach to replace those (not yet installed); one is -30 to 30 psi boost, and the other is a dual gauge that shows fuel pressure and EGT
  • Upgraded stereo stuff (nothing to shout about, just "better than stock" . . . Aiwa head unit, forget what brand the door speakers are (Panasonic?), and an easily-removed sub-box in the hatch (not built in)
  • Tranny recently completely rebuilt and freshened
  • ACT 2600 clutch
  • short shifter and bushings
  • Salvage yard "big-brake" upgrade (not yet installed)
The motor is currently out of the car; I slagged the #2 piston at the track and it scored the block. I happened to have a bottom-end from a '90 (a parts car that I own), and the head was undamaged (and recently freshened), so the rebuild shouldn't be too painful. Nothing special planned for the rebuild other than '95+ pistons, which will bump compression slightly (should improve off-boost performance a bit).
So far on the WRX:
  • TrunkMonkey!
  • Thermal R&D 3" cat-back
  • Godspeed up-pipe
  • Stromung downpipe (hi-flow cat)
  • 17" Rota Tarmac wheels/Falken Azenis tires
  • Defi HUD boost gauge/turbo timer
  • Color matching OEM side skirts
  • K&N panel filter; hacked airbox
  • Prodrive springs, to-be-installed (TBI)
  • Goodridge braided stainless brake lines, upgraded pads (TBI)
I have plans to add an intercooler sprayer this spring, maybe fuel control if I can drum up a few $$$ detailing friends' cars with the warmer weather. The computer is about $1000, but worth about 20 whp on an otherwise stock car, plus the ability to tune for modifications as they start to exceed the abilities of the stock ECU.
That's an"Imprezive" mod list......
I'm glad I'm not the only MOD-MANIAC around here!:cool:
The highest compliment I have been given on my mods is this:
"Your outta control.......I mean seriously outta control!"
I responded: "Thank you."
(I NEED TRUNK-MONKEY!)
Ah, but to get a TrunkMonkey, you must first acquire the Beauty of All-Wheel Drive :D
Me, a mod-maniac? It's not my fault modifications are like 'tater chips . . . betcha can't install just one.
Tort
Luster I must say your car is one of the most tasteful modifidied cars I've seen in a very long time. Not to much not to little just very classy.:xyxthumbs
Thanks, Detailbarn.......
It's easy to "over-do-it" when it comes to mods.
I subscribe to the less is more theory. :)
Your theory goes with my mod list. Cat back Flowmaster, 4x4 wheels, and a chopped intake.
If I had to guess I'd say I have around $3K in mods to the car. I don't keep track ;)
Performance modifications
  • Magnaflow Magnapack cat-back exhaust w/3â€� polished stainless steel tips
    Ford Racing underdrive pulleys, C-Springs, aluminum drive shaft & 3.73:1 gears
    Steeda Tri-Ax shifter, timing adjuster, sub-frames & G-Trac bar
    Yo! Dude Racing X-pipe
    K&N air filter
    Maximum Motorsports Urethane spring isolators & Caster/Camber plates
    Interactive System Technologies 180* fan relay kit
    Aeromotive adjustable fuel pressure regulator
    Russell braided stainless-steel brake lines (front)
Cosmetic/Interior/Exterior modifications
  • Steeda Polished aluminum door sill plates, headlight & A/C knobs
    UPR Billet aluminum window/mirror/door lock switch buttons
    Pro-Fit polished aluminum electric fuel door
    MAC White faced gauges
    Ford Mustang Bullitt pedals
    Autometer dash pod & main cluster bezel
    MGW Ltd. Aluminum door lock pins
    Hurst chromed shifter handle w/Classic knob
    Carbon-fiber emergency brake handle
    Clear corner markers
    Isotta chromed aluminum shifter ring
    Ford Racing 2� water temp, oil pressure, fuel pressure and volts gauges
    Ford Racing export fender flares
    Performance Wheel Outlet polished 17x9 & 17x10.5 “Motorsport R� wheels w/245/45/17 & 315/35/17 Sumitomo HT tires (to be replaced with Pirelli P7000 in the rear on 2/26)
    Saleen S-281 rear wing
    Interactive System Technologies hood struts
    “Old Ford Blue “Painted front and rear brake calipers
The Carrera C4S has a Bilstein coilover fully adjustable coilover suspension with euro spec swaybars and shocks. Euro clear indicators and fogs. Brey Krause Stainless Steel Front Strut Bar. Custom air box for better breathing, K&N filter. Plus a few interior aesthetic mods.
The Audi S4 has a Neuspeed 19mm adjustable rear swaybar, Euro HID's, with city light mod, clear corner indicators, RS4 grille, BMW M3 rear lip spoiler, red painted calipers, K&N filter, rear interior sunshade, Panasonic 6-disc CD changer, VW New Beetle overhead sunglass holder, Porsche dual horn upgrade.
well lets see...
BBK 52mm Throttle body
March power pulleys
Granatelli Mas air Flow Sensor
Hotchkis Strut Tower Bar
Pro 5.0 shifter
SLP Air Temp Module
"Deconed" SLP 2ontheleft exhaust
LT4 Knock Modual
Spohn Lower Control Arms's
Spohn Panhardbar
Ed Wright Computer reprograms
LT4 Clutch
5% tint
K&N air filter
GM alum Driveshaft
Mobil one synthetic oil
Mobil one synthetic Tranny fluid
Mobil one Synthetic rear end fluid
(hand)polished intake
(hand)polished Throttle body
(hand)Polished alternator
(hand) polished exhaust
Throttle body coolant bypass
Clarion CD player
Alpine EQ
Boston acoustics Component set
JL audio 6.5's
(2)JL 12W0's
Q Lojic sub box
Precision Power amps
Custom made amp rack
Chrome SS wheels ( I have the stock painted ones too)
Red painted Brake Calipers
I am sure there is more but cant think of them now...
Here is mine:
Stillen Rear Sport Wing
Stillen GTZ Front Spoiler
Stillen Type III Rear Valence
Stillen Door Skirts and door fillers
Stillen Polished Dual Tip Exhaust (2.5")
Stillen Polished X Pipe
Stillen Cross Drilled Rotors
Stillen Louvered Center Panel
Stillen Rear Strut Bar
Nissan OEM Clear Corners
HRE 540 Fully Polished Wheels-17x8 front and 18X9 rear
Toyo T1S Proxie Tires-265/25/18-rear and 235/44/17 front
Painted Calipers (Black)
SGP Oil Cap
Hose Techniques Yellow Silicon Vac Hoses
Red Upper/Lower Radiator Hoses (Avalon Racing)
Red Silicon Intake Hoses (Avalon Racing)
Carbon Fiber Fan Shroud (Avalon Racing)
Carbon Fiber Timing Belt Covers with Polished Bolts
Carbon Fiber Throttle Cover
Carbon Fiber Interior Trim Pieces
JWT Intake
Erol's Stainless Steel Fuel Lines and Connectors
Erol's Stainless Steel Brake Booster Lines and Connectors
Goodridge Stainless Steel Brake Lines
99 Nissan OEM Jspec Red Stitched Shift Knob
Red Leather Stitched Shift Boot and Ebrake Boot
99 Jspec Carbon Fiber Stereo Console
99 JSpec Optional ALTIA Aluminum/Indiglo Illuminated Door Sills/Scuff Plates
99 Fairlady OEM Rear Center Panel (Red)
99 Jspec OEM clear taillights
Chromed EGR Tube
Chromed Upper Plenum Fuel Rail
Chromed Power Steering Res
Chromed Cruise Control and Fuel Regulator Bracket
Chromed Hood Security bracket
Chromed Battery Tie Down Bracket
Chromed Oil Dipstick Handle
Chromed Top Speed Front Strut Bar with Chrome Mounts
Chromed Hood Latch and Bolts
Chromed Wiper Relay Bracket
Chromed Throttle Body Springs
Chromed Power Steering Pulley
Chromed Water Pump Pulley
Chromed Custom Radiator Air Guide
Misc Chromed Engine bolts/brackets
Powdercoated Balance Tube (Yellow)
Powdercoated Coil Pack Brackets (Yellow)
Powdercoated Rear Sway Bar (Yellow) with Red Energy Suspension Bushings/Endlinks
Powdercoated X-pipe suspension brace (Yellow)
Powdercoated Rear lower suspension control arms (Yellow)
Powdercoated Rear subframe brakets (Yellow)
Polished Plenum
Polished Throttle Bodies
Polished Crack Angle Sensor
Polished Cruise Control Unit
Polished AC Reservoir
Polished Misc. Wiring Brackets
Polished Nissan Fuel Filter
Polished Hood Prop
Polished Water Inlet Pipes
Polished Fan Clutch
Polished Hose Techniques TBolt Clamps
Custom Nissan Aluminum Pedals
NISMO Racing Radiator Cap
NISMO Fuel Filler Cap
Optima Yellow Top Battery
Painted sub frame and differential with chromed differential bolts
Custom Cut Mirrored Engine Accents
Custom Trunk Z Logo
Corbeau Carrera Leather Racing Seats (Red/Black Leather)
PIAA Xtreme White Clear Corner bulbs
PIAA Xtreme White Fog Lights
Autometer 2 1/16 carbon fiber gauges in custom glove box pod
Custom Ztoyz.Net Red Stitched trunk carpet
Custom Painted Brake and Clutch resevoir caps (Yellow)
Custom Painted Battery Tray (Yellow)
Mr. K signed visor and T-top shade
Zdriver.com "Project 300ZX NA"
Sponsors: Meguiars Wax
Avalon Racing
Londonderry, NH
(www.Avalonracing.net)
Used300zxparts.com
Brooks Plating and Polishing
(Philadelphia, Pennsylvania)
Pakshak.com
What I HAVE:
- JWT intake
- 2002 Maxima strut tower brace
- US-spec "4DSC" sticker :p
I'm going to start a similar thread for what I wish I had...
Pats300ZX....
My wife would say....."Pat has some serious issues!".....
I would say...."WHAT AN AWESOME MOD LIST!!!!"...:xyxthumbs
Isn't this a great hobby!
I absolutely love it.:D
You know the story about the difference between men and boys....its true.......(price of toys).....
Redcar GUY said:
well lets see...
March power pulleys
Pro 5.0 shifter
SLP Air Temp Module
LT4 Knock Modual
Spohn Panhardbar
LT4 Clutch
5% tint
K&N air filter
GM alum Driveshaft
Clarion CD player
Alpine EQ
JL audio 6.5's
(2)JL 12W0's
Q Lojic sub box
Is that on the Saturn or cavalier? :D
not many mods for my car,
front and rear strut bars
aem short ram intake
msd ignition
apexi vafc
hondata intake manifold gasket
coilovers coming soon
but i would have to say the best mod i've done so far....is get the bridgestone s03's for my tires! they grip like no other tire, even in the rain! :eek: :D
On my WRX:
Vishnu Stage Zero
Catless up pipe
underdrive pulley
colder plugs
boost controller
Unichip engine management
StopTech big brake kit
Prodrive springs
Whiteline Anti-lift kit
Whiteline adjustable rear swaybar
Kartboy rear droplinks
Kartboy shortshifter & bushings
17x7.5" Rota SDRs with 225/45/17 Falken Azenis Sports
DIY painted sideskirts
Custom gauge pod with 3 Autometer gauges (oil press, oil temp, EGT)
TRUNKMONKEY!
And much more to come soon :D I'm not stopping until I'm at 350hp and then I'll be happy ;)
For the Alfa:
Swapped 2.5L engine for rebuilt 3.0L
Sperry stage II heads
10.5:1 pistons
IAP headers (jethot coated)
Modified ECU & Ignition module
Larger AFM + K&N Cone filter
4.10 + LSD transaxle (modified for more lockup)
Supersport springs & torsion bars
larger front & rear swaybars
Koni Sport adjustable shocks
Lots of polyurethane bushings
Slotted brake rotors front & rear
Stainless steel braided brake lines
Porterfield R4 pads
Completely gutted interior
Lightweight racing seats
Sabelt 5-point harnesses
Autopower 4-point rollbar (soon to be full cage!)
Momo Millenium 350mm steering wheel
Momo Race airleather shift knob
16x7" SSR Integrals with 205/45/16 Kumho Ecsta V700s (recently sold)
DIET! Removed interior, power steering, A/C, Stereo, etc
And probalby more that I can't remember at the moment ;)
mods:
PIAA Super Plasma 5000K headlamps
PIAA Super Plasma SX 3800K 85W fogs
Raceconcept's Cross-drilled & slotted Rotors
Hawk HP+ front Pads
PRB rear pads
Magnaflow's Cat-back exahust
18" Mille Miglia Emotion SSL rims w/polished lip
225/40/18 Yokohama Parada Spec 2 tires
Eibach Pro-kit
D3 Designs (CSK) chassis stiffening kit
Road Race Engineering/Koni Front struts
KYB AGX rear shocks
Magnecor KV 85 plug wires
Denso Iridium plugs
K&N CAI
Kenwood Z828 h/u
Alpine V-12 Amp
Momo c/f shifter
Ichibahn pedals
Euro clear turn signals
35/20% Llumar tint
Grillecraft silver grill
and a box of Swiffers!
That pretty much keeps me up and running
I've been very impressed by the various "MOD LISTS"!
It inspires me to go out and spend MORE MONEY!
The highest compliment you can be paid, when someone looks at your car is this:
"You're Out Of Control!!!!
You respond. "Thank you."
