Current best wheel coatings 2024 - Seeking recommendations
AOE
Hey all, long time lurker from way back that could use the help of the community on selecting a modern coating to protect two new wheelsets that I`m going to be getting mounted/installed soon. First set is chrome-plated, the second set has a standard clearcoat.
For the first set, because they are triple-chrome plated, I`m looking to protect them as best as possible from pitting/corrosion. These wheels are freshly plated from Sensei6 which is a well known powdercoating and wheel refinishing company based out of CA. As far as I know, their plating process is true triple-chrome, meaning the outter layer is chromium and not a clearcoat. I bought them 2nd-hand-new, so I`m giving Sensei6 a call on Monday to confirm. The second set have a clearcoat on them from the factory, so i`m not as worried about those but will be coating them all the same for ease of cleaning and protection from road salt/chemicals.
Both wheels will see HPDE track use in spring/summer months, as well as daily driving year-round in the north east (NJ/NY area) where salted roads are the norm over the winter, so I`m looking to give them the best defense possible.
If my priority is protection and longevity, which wheel coatings would folks recommend for such an application? I`m happy to use toppers at regular intervals to keep it going.
Bonus points for having good ease-of-use and ability to withstand higher temperatures (as the wheels will get pretty hot from hard braking during track use), but as long as application is not terribly fickle, I don`t mind.
I`ve gathered a rough list of products to consider just from some casual scrounging of the forums, but unsure which would be most appropriate for what I`m looking to achieve:
- 22PLE VM1
- Kamakazi Stance
- CarPro DLUX
- The various Opti-Coat products (Opti-coat 2.0? Opti-coat metal?)
- GTechniq C5
- Pinnacle Black Label Diamond Wheel Coating
- CQuartz
- I`m sure there`s a ton more and many that I`m not aware of...
Thank you for your time and advice!
EDIT:
Some obligatory wheel porn B). First set are chrome plated TE37s going on a 2nd gen BRZ, second set are diamond dark gunmetal ZE40`s going on a MKV Supra.
An of course, some pictures of the cars themselves.
Opti-Coat 2.0 has been gone for many years, Opti-Coat for metal, and all the Opti-Coat products (other than the maintenance products) are pro-only. A couple of wheel coatings you may have left off are Gyeon Rim and Armour Detail Supply`s wheel coating.
Ah, thanks, didn`t know that re Opti products.
Based on some thoughts expressed in this thread, it seems the durability of Gyeon`s Rim isn`t up to par for what I`m looking to achieve.
It also looks like 22PLE VM1 is unfortunately no longer sold, at least to the public.
^^^Yes, unfortunately 22ple is kind of MIA...
I`ve always had good luck with Dlux
Ended up going with CQuartz UK 3.0 due to seeing some other folks having good experiences with it on chrome and some anecdotal feedback that it lasted longer on wheels than DLux. I`m sure they`re both excellent. Shame that 22PLE went under, seems like it was a very well regarded product among the community.
Thanks all.
