Cure time... HD Speed
Dellinger
I am wondering when HD Speed should be removed?
I read the instruction on HD's website but it didn't mention it specifically.
I do know that a hybrid wax/ sealant, similar or the same as Poxy,  is present in the product for the protective aspect.  The Poxy instructions are to let the product cure for 30-45 minutes before removing.
So, should Speed be removed after each section or allowed to cure for a longer period similar to that of Poxy?  (I assume the latter.)
Many thanks,
-Gabe
I just do the whole car then go back and buff off the haze.  Has always worked great with very easy removal.
I did it a section at a time, it wouldnt be "speedy" if it had a cure time,, though I dont see any reason leaving it on would be a problem.
You can use this product 2 ways:
**Buff a section and remove
**Buff the entire vehicle and remove.
My personal recommendation (because it's part polymer sealant) is to go with the latter. I will polish the entire car (permitting a clean environment) and leave the residue on the surface after polishing. Then, once the vehicle is completed polished I remove the residue. Doing so will not hinder the ease of removal, but I think it allows the polymers to link up allowing for a better bond.
