Cure time for SG?
JohnSWA
I'm curious about the cure time for Klasse SG. Why do you have to wait 24hrs? Does this mean leave it on for 24 hrs and then buff off? Or does this mean buff immediately and then wait 24 hrs to apply another coat? I've buffed off immediatlely and had great results.
I've also had a difficult time buffing this stuff off sometimes. I used a damp terry applicator with meg's QD and it went on real well with a thin coat, but I"m wondering if I should use an even thinner application?
Thanks in advance for your awesome advice. Man, I love this site!:xyxthumbs
John
You should wait at least one (1) hour before removing SG. Some say that the longer that you keep it on the easier it is to remove.
The best way I have found to remove it is with 2 MF towels. One damp and one dry. Make a pass with the damp MF then follow with the dry one. Makes the removal quick and easy.
You want to wait at least 24 hrs between coats of SG to allow it to cure.
Hope it helps....
