Just to clear up a couple definitions, or at least how I use the definitions...
Dry time/Haze time: This is the time from which a liquid sealant is applied to the paint to when the sealant has fully dried to a haze and is stable. At this point you can swipe a clean finger across the surface of the hazed surface, and it should swipe away a clean with no streaking. At this point the sealant can be removed from the surface.
Cure time: This is the time, after removal of the hazed residue, in which the chemical reaction of the sealant is fully completed. At this point the sealant will be at its brightest and offer the most amount of protection, in addition to be chemically stable enough to accept other coats of sealant or wax with full benefit.
Both the dry time and cure time are going to be dependent on a variety of factors. Cooler temperatures and higher humidity will tend to lengthen both the dry and cure time, where as excessively thick applications will lengthen the dry time. In drier and warmer climates the times will be shorter. CMA always recommends applying which ever wax or sealant of your choice as thin as possible, just enough to ensure even coverage over the surface.
Blackfire Wet Diamond Sealant now features the Polycharger polymer which will decrease the amount of time required for dry time and cure time. The addition of Polycharger should give Blackfire an advantage over FMJ in this respect. At the very minimum, I recommend at least 4 hours between coats, although 12 hours is best. I have applied two coats of Wet Diamond Sealant back to back, with no streaking or ill effects, but I probably didn't get the full benefit of two separate coats. The best rule of thumb is to wait as long as possible between coats, as it is possible that applying coats with in a four hour period could lead to some streaking.
Blackfire Midnight Sun Carnauba, batch 24, also features a slight polymer additive, designed to bite into even the slickest sealants and promote better bonding. This is why Midnight Sun seems to work well over every sealant. However it is a high percentage carnauba paste wax which requires some time to fully harden. The application of Blackfire is unique, as it is designed to be wiped away wet. Apply the wax to a section, like half of the hood, then immediately buff off to a deep shine. The high percentage of carnauba still needs some air time to fully harden. I personally recommend about two hours before adding another coat of wax, on top of a previous coat of wax, at the minimum. Due to time restrictions, I have applied two coats back to back of the Midnight Sun and once again, never had bad effect.
So, ideally we would allow as much time as absolutely necessary to allow the wax or sealant to harden or cure, to receive the maximum benefit.
The reason that two coats of each product are recommended is to achieve a uniform coverage over the surface. Since two coats, for this reason, are always recommended over one coat, if you don't have time to wait, you can apply two coats back to back (try to give some time) to get a more even coverage. You likely won't get the full benefit of having two coats, but you will still have more even coverage then one coat.
Another thing to keep in mind is that even one coat of either product provides great looks and protection. On my personal car where I don't have the logistical situation to keep my car out of commission for 15 hours while I apply multiple coats of products, I apply one coat of Blackfire Wet Diamond Sealant after detailing. After my next wash, I will add an additional coats of Wet Diamond. After my next wash, I will will apply a coat of Midnight Sun, and that after the third wash, I will add an additional coat of wax.
Hope this helps!
Todd
