bud659 said:I bought a used 9227c to since my PC wasnt correcting the deep scratches. I used a 3/M foam pad with their Perfect-IT Swirlmark remover. I kept the buffer moving and I still managed to burn the paint. Any suggestions?
bud659 said:I dont understand how i created these marks. maybe its holograms :nixweiss?
The 9227c is on a setting #4, 2100 RPM and my arm speed covered 2 feet length in 10 seconds with medium pressure. I had a few problems with the buffer 'jumping' out of control so I put more pressure on behind the handle. It was as if it skipped out of my hands. The foam pad was flat on the surface and I am using 3/M Perfect 3000 06064 SM Remover. This is my first time with these products and buffer.
Here are some pics. Sorry for the bad red arrows.
dsms said:I cant really see a burn through, it looks more like buffer trails to me. A closer pic would help to see if you did in fact burn the paint IMO I think you probably did due to teh speed and pressure used. FYI 2100rpm is way to fast!!! You should not need to surpass about 1700rpm max. For correction normally I go at 1500rpm(speed 3). 2100rpm and lots of pressure will cause a ton of heat buildup and you are more likely to burn a clear.
mystic04 said:I just got my rotary last week de walt 849 for a good price.well last night was my first time trying it out with the edge waffle pads, on my red explore hood used a blue pad to start off with and some 106,. After hearing all the horror stories of rotary use. i found it's not the monster all have said it is . true it's only one hood on one car but it gave me the confidence to use one now It started off at 1000k for a few passes and 2 sections then moved up to 1400k on the second 2 sections and wow it turned out rather nice for first time use. Reading here has hepled a lot on which speeds to use where most have said no more than 1500 or under which i plan for now to stay at and just use the blue light cutting pad from edge.Till i can try out a few other pads and see how things work and which works best to get the resulted one is looking for.I think for now i will use the rotary for just the hood and roof and trunk lids to save time then use the flex and or Pc for the doors and smaller places till i become more use to the rotary.
JuneBug said:Excellant article "howareb" ! Should be required reading for anybody using a rotary.
robert said:+1! just got done reading that article and think im gonna read it over again. seeing how i just bought a Mak, its very informative for the rotary newbie like myself. thanks again for putting up that link howareb
