I'm detailing a white Volvo XC70 that is long overdue for one. A couple of years ago the sunroof shattered and I used duct tape to hold a plastic sheet over the opening until the new glass arrived.
Since then there has been a blemish where the tape damaged the paint;sort of looks line some lines in the paint.
I will be using a pc 7424 for the first time and am working on the order of needed supplies. I have on hand Menzerna power gloss for the first polishing;when I applied it to the above mentioned area with a micro pad it did improve the paint quite a bit but some lines still remain.
I'll be ordering lake country CCS pads-orange for the power gloss and am wondering if that will be enough to correct it or if this where a yellow pad is necessary. The power gloss will be followed up with intensive polish and final polish h using the appropriate pads.
Advice on the problem is appreciated.
thanks
thanks
