Confused on layering
imported_kgb
I am confused about layering. If I want to layer Poorboy's EX do I put a coat on then wipe it off then put another coat on? And if I want to layer with P21S Carnuba do I put on Poorboy's EX wipe it off then apply P21S or is the second coat applied on top of the first coat?
Ive layered S100 before, just apply like you normally would, buff off, then just apply a 2nd coat, thats it, im travelling to N.B next weekend, so ill be applying about 3 or so coats on the front area anyway
Since all protectants (both synthetic & carnauba) that I’m aware of contain solvents and/or carriers that must be wiped off, the only way to go when layering is to go through the full process with each layer.
Another thing to consider is that after the product has been wiped/buffed it will most likely need 6-24 hours of curing time to get the best results before adding another layer. The needed curing time is highly variable depending mostly on the particular product in the case of synthetics, and the thickness/thinness of application for carnaubas.
Good luck and have fun!
