JustJesus
THIS IS NOT A THOROUGH REVIEW OR COMPARISON
(Just a brief summary of my thoughts and/or experience with five 2-step combos)
Objective: Trying out products! When I first started, late 2014, I started with Meguiar`s Ultimate Compound and Ultimate Polish. Soon thereafter, I learned about and used the ever popular M105/M205 combo. Then I learned about other 2 step combos, aka Twins, such as the Blackfire SRC Twins, the HD Cut/Polish Combo, etc. Well, over the course of just over a year, I wanted to get my hands on as many samples as I could get. Why? Because there came a time when my go-to combo (M105/205) didn`t work on my most important job! I picked up Menzerna FG400, and it worked. I also picked up Megs D300 and MF Cut Discs, and I was in awe.
Anyway, I`ve read reviews, seen videos, and I wondered if I was missing something. So when chances come up to get sample sized products (Thank you Poorboy`s World for making just about everything in the line-up avail in sample sizes!), I did.
ON TO THE TESTING!
The Players:
- Chemical Guys V series. V32, V38
- Meguiar`s M105, M205
- Wolfgang Uber Compound, Finishing Glaze 3.0
- Poorboy`s World Master Cut, SSR2*
- 3D AAT Rubbing Compound, Finishing Polish
- HD Cut, HD Polish**
Note: In some cases, such as the CG V Series, I had multiple choices of polish to use, but I tried to align all the products as best as I could. For example, I used the heaviest cuts, based on the chart on Autopia. For the polishes, this was a bit harder to do, but I tried my best to keep it "even"
*For Poorboy`s, I was initially going to use either the Pro Polish, or Pro Polish 2. As noted above, I tried to keep it "even" so I went with the SSR2 as it was more in line with the others.
**As much as I would have loved to have included HD Cut/Polish, the panel I was working with didn`t have enough space on it! Otherwise, I had a few other combos to throw into the mix.
Tools:
- Meguiar`s MT300
-- Used for the first four combos
- Flex PE14
-- Used for the last one, the 3D AAT combo
Note: I switched to the Flex, as my research indicated that the AAT products were designed with the bodyshops in mind, and it seems, also, they were designed to be used with rotaries and wool pads for compound. I did similar with the other combos, and I couldn`t find anything that would tell me I should use a certain tool/pad combo for the other products.
Pads:
- Meguiar`s MF Cut Discs
- Buff N Shine Wool Cut Pad (only used with the 3d Compound)
- Lake Country Flat Foam White Polish Pad
- Chemical Guys HexLogic White Polish Pad (only used with the V38)
- Buff N Shine Yellow Foam Polish Pad (only used with the 3D Polish)
Note: All pads were the 3" variety, with only the HexLogic being a 4". Okay, I THINK the wool pad is considered a 3" pad.
The Test Panel:
- 1991 (give or take a year) Honda Civic Hatchback. Light blue in color, with clear coat.
Note: Not sure what happened with the lower half of the panel. That is how I got it. It looks like either clear coat failure of some sort, or maybe prior owner tried sanding it? Not sure
Surface Prep:
- Cleaned with degreaser. It was downright nasty. Been sitting for a long time before I bought it years ago. Then it sat some more.
- Washed with (oops, forgot)
- Clay`d with Poorboy`s World Clay, Lube. (Love this stuff. I really was tempted to taste it this time around!)
- SANDED
- I wanted to test for cutting ability as well as finishing with the compounds, so I did some wet sanding. Oh, I also wanted to get some more sanding practice AND try out a new-to-me product: Mirka Abralon
- Started with Abralon 1000, followed up with 2000. Wasn`t trying to level it flat, just to clean it up a bit
After damp sanding with the 2000. Reflection is pretty much gone!
Close up of the panel after damp sanding. Pretty uniform sanding marks left behind.
How the panel was broken down
Compounding completed
In the sunlight (lousy panel to test on!)
Close ups. Chemical Guys
Close ups. Meguiar`s
Close ups. Wolfgang
Close ups. Poorboy`s World
Close ups. 3D AAT
Results after the 2nd step, polishing
-Chemical Guys
- Meguiar`s
- either Wolfgang or Poorboys (I deleted one of the pics)
- 3D AAt
