Well I was lucky enough to attend a Meguiars Car Clinic yesterday and asked Mike if I could raid his shelf full of products! No objections from him so I grabbed a barely used jar of Souveran and decided to do a camparo of it vs Nxt.
I started by dusting the entire surface of my hood with a CD. I then used Final Inspection and an MF to remove any light dirt.
I read the Souveran suggestions which recommended applying the wax and removing it just before it had completely hazed. So I applied the Souveran to the drivers side of my hood.
I then grabbed the Nxt and applied it to the passenger side of my hood.
As soon as I finished applying the Nxt I went back to the Souveran side and removed it. It had just barely hazed over as I was removing it.
Here are MY observations:
1. Application: Nxt and Souveran are equally easy to apply. They both are very easy with regards to effort. Both products were applied with a Megs Yellow Foam Pad by hand.
2. Removal: Both are very easy to remove as well although I noticed significantly more dust with Souveran. I'm thinking I may have used just a bit too much product but not sure. I also noticed that Souveran left white inside all of my paint chips big or small. What wasn't visible before was not very visible, I need to use a toothpick to clean all the chips, not too thrilled with that.
3. Appearance: Well I have to admit, Souveran definitely is just slightly darker than Nxt. Both sides allowed my metallics to pop though! The Nxt side was slicker and slighter brighter in appearance........a bit more reflective I guess.
So would I buy Souveran, probably not. It looked really good but the marginal difference in darkness isn't worth $50. That doesn't mean I didn't like it, just didn't wow me to the point where I need to spend $50.00
