Collinite
If you are referring to their paste wax, it's very challenging to remove. the IW is their most popular product, by far.
lawrencea said:
Collinite is the most durable carnuba.
Well, to be more specific, The Wax Report says that Collinite was the most durable of the waxes that they tested, according to their methodology.
And I'm not knocking either C nor TWR, kudos to both for their excellent products; I only want to put the knowledge of C's durability in its context.
You can tell, as you apply it, that it's going to last; it's heavy as all hell.
Tom
I really like Collinite's 476S. No, it DOES NOT look as nice as higher-end waxes, hard to verbalize, but it looks a little "worse" than Meg's #16. Not quite the same depth, wetness, or clarity. So it's probably not the stuff to use before that big car show unless it just happens to look great on *your* paint. BUT, I honestly think that comparing most paste waxes is pretty pointless, we're talking *VERY* subtle differeneces. Souveran and Collinite are not really designed to accomplish the same thing, except in the most general sense.
The Collinite goes on/off just fine for me. I apply, and usually remove, it using a PC or Cyclo. You can wipe-on-wipe-off and still get good durability, or you can let it set up longer and get even BETTER durability (with a little tougher removal). It did NOT stain my trim. It hides a LITTLE marring and seems to "layer" if you apply the subsequent coats with a week or so in between. On a vehicle that's outside 24/7 it lasted all winter, and then some, with two coats (one allowed to set up and one w-o-w-o). On the light/medium blue Volvo single-stage, *I* though it looked great. Incredible beading, "self cleans" in the wet.
Great stuff! The IW I used on my wifes car lasted all winter sitting out 24x7. The IW is easier to apply and seems to have a very slightly better appearance than 476. But personally I think 476 does have a nice llok and protects even better than IW. On the cars I have used Collinite on the IW was a breeze to apply/remove and even 476 when left to haze for 15-20 muinutes wasnt bad at all to work with (but not in the same league as NXT or Wolfgang for ease of use).
