I just washed my truck and decided to take a few pictures :-B
My wax of choice was Collinite 845, and it was applied a few weeks ago.
I love how this wax beads! Another thing you will notice
is how well it works on the plastic mirror housings :thumbup:
Each Image is hyperlinked to a bigger version,
so you may click on the image to make it bigger if needed.
I posted this in another thead, but I'll add it to this thread. It is a few ways I have found that make 845 easier to use.
- Shake it up! It will liquify into a melted butter consistancy. This helps with the next point.
- Thinner is better. I put 845 in a spray bottle [and now other companies have started selling it with a spray head] as it is a really easy way of applying thin. I spray [mist] a MF applicator and I can cover an entire panel with just a mist. Put it on thin enough that you are wondering if you are even applying it. If you find the 845 to almost flash when applying, it is going on thin enough.
- Do not let it dry. When it hazes, you can remove it. Problem with applying it too thick, is the difficulty of buffing it off in its entirety. If you let it dry, it will be as hard as a rock. Wax 2 panels, and go back and buff the first, apply to a new one, then remove from the second panel, apply to another, repeat. This has worked for me in particular conditions, you may be able to wax the top, or side of a vehicle before removing.
- On my personal vehicles, I will often apply another coat. After letting it sit for a week,I'll reapply with "light" pressure and buff it off again with light pressure. 845 has some solvents, but with a delicate additional application, it will add to the longevity.
- Accumulator, a member on the other site, has found applying 845, then applying 476, to create a very protective layer of wax. Again, after waiting until your next wash, he applies another coat of 845. It creates an impressive combination for the paint.
- You can use it on plastics, but make sure you test a small spot first. Apply the wax, and buff it in like you are cleaning the plastic. Then, buff it off. Don't let it dry on the plastic, but apply and remove right after.
If anyon else has some pointers, feel free to add. I'm no expert, but this is what has worked for me.
:rockon:
