CharlesW said:Is there an inexpensive code reader for a 1998 Pontiac TranSport?
I'm looking for some way to read the code an "airbag" warning light would have set and a way to reset it.
Charles
Thanks.TriPinTaZ said:the airbag is not related to the cars PCM and you wont get any codes from it. And there is no other way to get codes from an OBD2 PCM without a scan tool.Autozone will read your codes for free, but like i said the airbags are unrelated to the PCM.
Thanks for the information. Is the control under the drivers seat in a 1998 TranSport mini-van? The reason I ask is that my Haynes manual shows it under the front passenger seat.maximv1 said:i work at a pontiac dealer and under the drivers seat, connected to the drivers seat belt plug in is the airbag control. you might want to have it checked out by a repair shop as it can affect the air bag performance.
The light is operating normally now. Flashes the seven times and then goes off and stays off which seems to be what it is supposed to do.Jngrbrdman said:Take off your negative terminal on your battery for about 30 minutes. That should reset the light.
Thanks for checking. The manual I have stresses that servicing the airbag system shpuld be done by trained personnel. That's not me.maximv1 said:hi charles, i checked the gm info site and with one of the tech's at work. the module i am thinking about on the drivers side wasn't installed there until 1999. that is why it is different in your manual. the gm site went through a wiring diagram for diagnosis, and the tech i talked to said airbag concerns can be pretty tricky if you not familiar with wiring and electrical repairs. i wish i could have been more help.
