I've read hours and hours of threads over the past few weeks on various forums and I'm still having a hard time figuring out what's best for the particular job at hand. I was hoping others' experiences could make the decision a bit easier.
I'm looking for a coating for a problem vehicle, 2015 Nissan (Super Black). The paint is super soft. Soft to the point where it seems that it scratches just by thinking about it. There are many foot long scratches along the sides of the vehicle as if it was driven through bushes. I'm assuming these were causing by winter coats and hand bags in parking lots. I'm ready to correct the paint (Iron, clay, 2-step), but don't want to do so until I have the right coating in hand, ready to go...
I've used Element 119's System X on a number of cars, and it was a tremendous coating, but Element 119 seems to have disappeared, and I've run out of it, so I'm back to square one.
I have some requirements in the relative order of need:
1) A coating that is harder than the typical OEM clear, that will help to prevent scuffs, scratches swirls.
2) Something that will last at least a full year in Northern New England (think below 0ºF cold, salt, sand, snow) .
3) Something that will be relatively impervious to bird droppings (This area reminds me of the Alfred Hitchcock movie, The Birds)
4) A coating that will allow bug remains to be removed without scrubbing (nightly clouds of flying sticky things)
5) Something that sheets more than it beads, due to very hard water and tons of pollen. (Our water actually goes through a softener first, but still water spots heavily, and they're hard to remove without polishing. It spots even while blowing the car dry).
6) A coating that can also be used on semi-gloss and flat black, plastic exterior trim.
7) A coating that does not need specific manufacturer's maintenance products (i.e. topping CQuartz with Reload). I'm looing for something that once done, it's done for the year other than washing and maybe the occasional coat of Permanon, or maybe CarPro Hydro2.
8) Something that has a WOW factor! Maybe a Wet or Candy or liquid glass look.
9) Slickness is not important per se, unless it's necessary for water sheeting (gotta get rid of the water spots and pollen)
I realize there is no BEST product! I'm concerned with each product's strengths vs. its weaknesses...for example, in my #1 request for hardness, If Optimum Gloss Coat was slightly harder than PBL Diamond Surface Coating but the PBL lasted longer, I might try the PBL instead. If two coatings were relatively close in performance but one had a much deeper gloss, that might sway me too.
Some coatings I've researched/reviewed are:
(the top 4 I think are the contenders although not in any particular order, with the remainder being the "also-rans", although maybe some of you have it switched around some).
22ple VX Pro Glass coating
Optimum Gloss-Coat
Pinnacle Black Label Diamond Surface Coating (is this much different than their Diamond Paint Coating? Is the difference just that it's multi surface?)
DP Paint Coating
BF Crystal Coat
DG Enviroshield
CP CQuartz & CQuratzUK (but do they need very specific maintenance products?)
GT EXOv2
Anything worthy I've left out?
Optimum Gloss-Coat
DP Paint Coating
BF Crystal Coat
DG Enviroshield
GT EXOv2
