Hey guys,
I usually don't post here, but I do read this board alot. But I did have an accident with shifing today I'd like your guys' take on. I was merging onto a road with heavy traffic after getting off an interstate with a curved exit ramp. So, when I merged into traffic, I had to shift down into second to get some power to get up enough speed. I drive a 2002 manual trans Accord, BTW. I must have not put the stick all the way into second, I'm not sure, but when I gave it gas, the car was not moving, so the clutch must have been slipping. Before I knew it, the RPMs were nearing 5000 RPM before I could get any decent speed and I started to smell something that smelled like burning rubber. I assume that it was the clutch burning, as I've never burned a clutch before. Since the engine and everything else was fine, I assume the clutch was slipping and caused it to burn some. I don't know if this happened because I didn't shift right, or what. I've been driving manual Accords for four years now, but I've never had problems until now. After this happened, I pulled over somewhere to get a quick lunch, and when I got back to driving, the problem did not occur again and everything was fine. I couldn't smell the clutch anymore, and all gears were shifting fine. This problem just seemed to come out of the clear blue. Do you guys think I need to have this checked out, or could that much harm have been done? :nixweiss Again, I've never had any problems like this, so I don't know if I'm in danger of the clutch going out or what. Thanks for any info and help!
