clearcoat - edge mapping
BMW_M
Since I repainted my car I noticed several ''clouds'' in my clearcoat visible from some angles. I searched the web and found they call these ''edge mapping'', so I wanted to ask, can I expect annything more from them or they are just going to stay like that?
I don't have a time to paint those areas again, and all of local painters are idiots so I will keep it as it is.
Maybe polish can help?
try lightly "dusting it with a hot air gun and see if that works ( worked in a bm dearlership and had quite a few like that) it sounds like "bloom" moisture trapped in the clearcoat bm use a waterbased paint so quite likely this will cure it just try a little section dont heat it red hot but just "warm it up a bit"
