Cleaning the clear plastic screen
nikro000
Member
Probably a rookie question - what would you use to clean the clear plastic screen on your instrument panel (the one that covers odometer, speedometer...) ?
Most glass cleaners are not safe for plastic.
Thanks
I havent really tried this myself but I think meguires has a plastic lens cleaner that "might" work for it. We'll see what the pros have to say. But thats what I would try to use.
There are a lot of products that you can use, but the thing to know is what you should not use. Using a strong cleaner can cause clouding. I like to use a safe plastic cleaner then go over it with a product like 303.
Novus is a great plastic cleaner it comes in 3 levels...#3 for removing scratches #2 for polishing #1 for finishing and cleaning...its available online....however you can use your glass cleaner....spray on a MF towel to get wet wipe that lens then buff with a dry MF towel
novuspolish
I use this on mine, although on my murano I have three indiviual round peices of plastic that I have found that they decolor if I use regular glass cleaner.
so I use....also on my LCD TV's
Monster® iClean™ Screen Cleaner
• Special MicroFiberTM cloth gently polishes your display without scratching it.
• Contains a special polymer to protect your display, while reducing static electricity that attracts dust.
• Liquid gel will not drip into delicate electronics.
• Alcohol-free, ammonia-free formula removes dust, dirt, and fingerprints without damaging your display’s protective coating.
Thanks! Sounds good!
On your Murano I keep a eye glass cleaner rag / towel in the car....they can clean the lens, smudge free no problem...the one in the center of the car is that one that I am talking about
I use this stuff on my NAV screen as well...and on the brushed aluminum too...which is a dust magent for some reason.
