Cleaning Suede (alcantara) seats...
Xtreme Racer
Alright well I have alcantara/suede seats in my car....they've gotten a little dirty.
I havn't tried anything in fear of ruining these seats (not cheap)
Just hoping you guys can suggest some things.
Also...how about the reconditioning of them? Meaning...the suede isn't "soft" anymore from all the usage..
Here's info straight from the source. It's in Adobe Acrobat (PDF) format, which I hope works for you.
http://www.alcantara.it/istituzionale/manutenzione_inglese.pdf
I myself have always used a Woolite and warm water mix on a white cotton towel, works great for slight soil, less so with really dirty Alcantara. I don't come across it that often, but it is easier to deal with vs natural suede (which is rare these days).
A soft brush used regularly, or a vac with a brush attatchment are also recommended. Hope this helps, cheers. :)
Yesterday I cleaned the seats in a WRX which are half alcantara. I used Autoglym interior shampoo and an upholstery brush - they came up fine.
To restoper the nap to alcantara you're going to need to use a solvent based product and agitate the material - just be careful not to agitate too much as you could permanently mark the fabric.
Ben
Alcantara®: although a synthetic material it has the look and feel of suede and stands up well to severe use.
Unfinished leather:
Some cars have untreated leather; soft, full grain leather made from an un-split sheepskin, lambskin, or kidskin, usually tanned with alum and chromium salts and dyed throughout.
The easiest way to tell is to sprinkle a few drops of water onto the leather, if the water is absorbed into the leather and looks like a stain, it's untreated if the water is not absorbed then it's treated.
Clean the surface with 303TM Cleaner & Spot Remover it removes even stubborn stains, including oil, grease, ink, berry juice, wine and blood. It contains no soaps, detergents, phosphates, nitrates, caustics, toxic organics, enzymes or volatile organic chemicals (VOC)
Using a soft upholstery brush to raise the `nap' of the skin then apply cleaner by spraying onto a 100% cotton towel (do not saturate) allow to air dry. The surface of these leathers has no protective barrier to protect them. As a result these leathers are very prone to soiling and staining. To protect unfinished leathers including suede, deerskin and unfinished dyed leathers, use 303â„¢ High Tech Fabric Guard.
Use on new or newly cleaned leather, spray on (but do not saturate) and let dry, it creates and maintains water repellence, resists soiling and helps protect against both water and oil based stains.
Identifying characteristics- very soft to the touch will scratch or scuff very easily; water drops will darken the leather but it returns to its original colour after drying.
JonM
