Cleaning rims?
acopp1729
So my Mom's expedition's rims are coated with brake dust. I tried hot rims and that did very little. Then I tried simple green and that made a dent but not nearly good enough. Is there a stronger product to try?
Thanks
Adam
"Most" Expedition rims are clear coated. It sounds like they haven't been cleaned up in a very long time if after using those 2 quality products.
Are they similar to these EXPY wheels? Note, the before picture was after washing them with a variety of products. I've done 5 or 6 Expy's and find that they stain very easily.
As opposed to using an acid based cleaner, which I doubt will do "much" more than what you have, try a paint cleaner/polish. That's been my go to in situations just like this. Yes, it does take a little bit more time, but is worth it in the end. Afterwards, I would suggest protecting them (a seperate step).
I feel your pain! I have an '03 Eddie Bauer and the brake dust is horrific (not to mention the squeaking in the brakes) -- Ford's stock brake pads are awful...I usually clean my rims once / week w/ the A2Z, which does a good job, but I can't get the tough dust off either...
Not to steal your thread, but I am actually in the process of looking for new brake pads...any suggestions here would be greatly appreciated...I am looking at a new Rotex Brake pad (w/ some sort of white powder ceramic (to cut the brake dust)...
Bring on the suggestions guys!!!
Eagle One A2z with a wheel brush should do the trick. This stuff is incredible. You spray it on a, then watch the brake dust run off, it's that good.
The Eagle One is a good product but if you used 409 at 100% and its still there that's baked in pretty well. I have a steamer for those jobs, it never
fails to take it off.
I brought this after doing a BMW that had super baked on brake spots.
You do have to be careful not to get the area to hot as you can mar the finish. ANother thing that I find for me is I am in some what a hurry while doing cars for no reason at all. I do not allow enough time forn the product to work into the rims before brushing and rinsing. On the tougher jobs I go over ther rims 3 times or more depending on the rims and take my time that in most case has always taken 90% plus.
I also find is a proper brush is also something to think about. I have about 5 different brushes the can reach into certain areas which also helps.
