Cleaning pads with OxiClean?
skenzer
I seem to remember hearing that you can go about cleaning pads with OxiClean. Has anybody tried this? If so, what steps did you take, mixture did you use? and how were the results?
thanks
Brad
never heard of anyone cleaning their pads with oxyclean (microfibers, yes). an easier way is to buy this and spray it directly onto the pad, let it soak for 10 minutes, and then massage all the product out under some running water, done. it can be found at your local walmart for around $3...
BigAl3 said:
never heard of anyone cleaning their pads with oxyclean (microfibers, yes). an easier way is to buy this and spray it directly onto the pad, let it soak for 10 minutes, and then massage all the product out under some running water, done. it can be found at your local walmart for around $3...\r\n
\r\n\r\nThanks, I\'ll have to check that out. :)'
I throw mine in the washing machine with one large scoop of Oxy, mid sized load water setting. Clean as can be and hasn't messed one up period.
