How do I clean the MF applicator pads that have AIO and SG in them?
BTW, i'm a Klasse convert. 2x AIO and i'm letting the 2nd coat of SG dry now and i'm stunned! every bit as good as or better than the results I got with carnuba but with 1/10th the effort!
I squirt a drop of dawn onto the area which had SG or AIO and i just rinse under hot water in the sink, and work it up to a lather using a scratching motion with my fingernails.
I personally thought that using a carnauba (s100) was easier.. I'm always missing spots with klasse. nevertheless, the resulting shine is worth it to me.
My method is like raymond_ho2002's, but be careful about scratching with fingernails; you don't want to damage the pads. I just rub with fingertips, rinse thoroughly, then spin dry on my PC (lowest setting) or let them air-dry.
" I personally thought that using a carnauba (s100) was easier.. I'm always missing spots with klasse. nevertheless, the resulting shine is worth it to me".
Try Sonus Spritz, it seems to 'even' klasse out and you should avoid missing any spots.
I soak mine in a combo of Dawn and liguid Tide then put in my washing machine on the "Hand Wash Setting". It's a very very gentle cycle. I run them thru once with the soap they were soaking in. After the first cycle I run them thru again with no soap to make sure they are rinsed thoroughly. Then dry on low for maybe 20 minutes then turn the heat off and air dry.
