Cleaning ceramic coating
efnfast said:
Can ceramic coating (jet hot coating) be cleaned with 0000 steel wool and windex?
What are you trying to clean off of it? Jet Hot is notorious for being fragle, I wouldnt scrub it very hard. I would start with some car wash solution and a wheel brush.
Many companies will void the coating warranty if you use anything other than soap and water to clean. It was in large bold print on the info that came with my headers.
Like anything, start mild and work your way up. (brush and soap, like carnOObie stated)
Randy
Nothing right now - I"m just wondering for future uses
i never knew you could really polish jet hot coating? my headers turned a little dull, and itried everything i could on them, with no luck at all.
You can't polish them. The only thing I would use to clean them is a damp cloth or maybe some soap and water. But do not use steel wool or it will take the coating off.
