Coatings=crack
Active member
If you use other tire coatings, please do a review here:
Got time and weather to finally use the Tac systems tire coat.
Cleaned tires 1st using Griots foaming tire cleaner
Didn’t work well. Turned brown on 1st cleaning in 2nd and 3rd passes. Tire did look significantly cleanerbut figured foam shouldn’t have been white after 1 pass. Then used 303 T&R
Bought this over the McKee’s because Klasse act recommended and this stuffs the bomb! Just as I suspected on this pass browning again. 2 more passes and all was good.
If thinking of Griots foaming tire cleaner I believe cleans well but wouldn’t use it pre coating.
Note: tried 2 other cleaners on different tires.... will be using 303exclusively in tires now
All clean
Next coating:
Went on super easy. My method I settled on was spray 1 spray on carrand tire brush
Work into all crevices (tire sipes?) and between letters. Then level out with foam applicator
Did 3 coats this way.
All clean
Next coating:
