I don't have any good picures. Basically I washed and dried then applied the Mothers by hand and buffed off. Then applied the DG 106 let dry for about 30 min., applied the DG 106 over the top of the 105 let dry for about 30 min. and then buffed off. It is a very smooth finish and seems to be holding up well. I just thought that I could get some alternative recommendations that would provide an even better result. Maybe another combination of products leading up to the DG that would provide a higher gloss. I haven't ever clayed the vehicle since it was so new, so not sure that would make a huge difference.
I'm totally lost here.
Do you mean #601 Polish Bonding agent or did you use #106? That's not a DG product that I have any knowledge of.
If you used #601, it would be applied before the #105 not over the top of it.
Since I'm not sure of your procedure, I can only tell you what works good for me with the Duragloss line.
1. #501, Duragloss Marine / RV Polish to clean and polish the paint. #501 is a very good cleaner/prep.
2. #105, Duragloss TPP (Total Performance Polish) as the LSP.
3. #951, Duragloss AW (Aquawax) can be applied after the #105 has cured. I usually wait at least until the next day, sometimes until the next wash.
I do have #601 and have used it, but I really don't think it is needed after the #501. If you have it and want to use it, it probably isn't going to hurt anything, but I'm not sure it's going to be much help, either.
