Anthony Orosco said:
I would side here with Steve.
Claying works OK before polishing but really comes into play AFTER your paint is polished. The polishing usually takes place via a wool pad and a rotary. Clay the paint afterwards and you'll be surprised at the contamininates in the clay.
Plus you'll notice the surface is very slick.
Anthony
This bugged the heck out of me for the past several months as well...
There are times when I feel that claying is first, and others where I
feel that polishing is first. On some cars I find that I get heavier swirling
marks when I use a polish before doing the clay. On the other hand,
when I would use the clay first, it would pull up so much stuff, that it
became useless shortly thereafter. The polishing comes out great, but
I find that I would use up almost an entire bar when I do the claying
first. In some cases, I would run out of clay before i could finish the
car.
Nowadays, I just do a decontamination wash first, and then if needed,
I do a claying. It takes a little longer, but it insures less chance of
heavy marks in the paint when I do a polish.
