Claying plastic headlamps?
Jaymzx
My car has plastic headlamp housings. I've noticed that they seem to have some sort of bonded contaminates stuck to them when I feel them. They feel like paint when it needs a good claying.
From what I understand, you're not supposed to use clay on plastic, correct? I used some AIO on them but it didn't seem to help. :nixweiss
Suggestions?
I've clayed plastic headlights before and it worked just fine. :nixweiss
After you clay, use some Plexus (let it sit on the headlights a minute) and an MF. You should be pleased with the results.
I'd say give the clay a try :xyxthumbs
Thanks for the tips, guys.
On another note, would multiple (3+) layers of SG on the headlamps help protect from sand chips?
I have clayed the plastic headlamp housings on my Isuzu VehiCROSS and my Chrysler 300C. So far, I have nothing but good things to say about it. Cleans them up without problems. No hazing.
That said, I would use a fine grade clay ...not one of the more aggressive grades.
.....BH
Unfortunately, no. It would however help ensure the plastic has some protection in the same way it protects paint but a small stone travelling at say 60 mph is not going to be stopped by a micro layer of any sealant
There is a product that is a clear sheet of plastic that you apply to the headlamps. Sorry I don't remember the name, but I think it is a 3M product. It is designed to protect headlamps from chips.
Quote: There is a product that is a clear sheet of plastic that you apply to the headlamps. Sorry I don't remember the name, but I think it is a 3M product. It is designed to protect headlamps from chips. Steve530
I've used these on headlights-
Protecting Headlights against Stone Chips:
Protect your headlights from stone chips, scratches and yellowing by fitting X-PelTM clear headlight protection. The pressed polished thermoplastic vinyl is optically clear (headlamp protection material blocks less that one tenth of one percent (0.1%) and will not significantly reduce lighting effectiveness.
The 40 Mil vinyl is flexible enough to adhere to contours and will withstand kicked-up road gravel travelling in excess of I20-mph. Fill a 16 oz spray bottle with distilled water and 3-4 ¼-inch sized drops of liquid detergent as a lubricant, plus it prevents the water from evaporating too quickly. Spray both the film and the headlight and place in position. The 3Mâ„¢ adhesive backing ensures that they are easily fitted, plus their UVR inhibitors will resist yellowing and fading (autosportcatalog.com)
JonM
$45 isn't too shabby and it's something I may consider after the housings are 'cleaned up'. They're not bad..only about 47K worth of use..but when I turn on the HIDs, every defect in the housing lights up like it's on CSI or something :)
