clay
ezzzman
if u dont open the clay from the plastic bag how long would u be able to keep them. coz i saw some good deal that u could buy four at the same time and save some $$$
thanks for the info.
and one more question would the meguiar #9 too strong to be used on a 3 years old paint, the paint shows some minor swirls and i'm trying to get them off with the meguiar #9 ( i always have my car garage kept)
Three year old factory paint or three year old respray?
For factory paint I doubt #9 will nearly strong enough unless you're using a rotary.
For a respray by PC, maybe, but it's still very mild.
By hand, fugetaboutit. Try ScratchX
PC.
What The Other PC said :xyxthumbs
And I just used some clay that must've been over five years old, and was kept in a very hot/cold building. It worked fine.
ezzzman said:
how would you guys compare on the product #9 and #7.
They're very different.
The #9 is a very mildly abrasive polish that also contains some Meguair's "trade secret oils" and, IIRC, some mild chemical cleaners. FWIW, my Jag has very soft lacquer, and the #9 is too mild to do much of anything on it.
The #7 is a nonabrasive product that is almost entirely "trade secret oils".
If the paint is already as good as it can get, you might use the #7. Otherwise, the #9 will do a little, very light, improving.
You could always use the #7 after the #9. But I dunno if it'd be worth it. I really only use #7 on single stage paints...
talking of #7 ive been playing around with mixing it in with #80 that way you can taylor the cleaning ability to your needs
Good idea, but you missed one thing ;)
The abrasives in #80 start out somewhat aggressive (too aggressive for some soft paints). Adding more lubricating oils via mixing in #7 won't change the *size or hardness* of the initial level of those abrasives so IMO it won't work out as planned.
A better idea would be to add the #7 to the (already so mild as to be a "why bother", but anyhow) #9.
Adding a glaze to an abrasive polish can work great (e.g., the current trend involving RMG added to polishes) but you gotta pick a polish with an initial bite that's closer to its "worked down" bite. The #80 just starts out too aggressive for this IMO. You're on the right track though :xyxthumbs
