Envious Eric
ok, i need to know of a better way to handle this situation...
dodge ram 2500 white = big truck that shows all dirt on it, bonded or not.
wash the truck with ONR, removes all surface level dirt, nothing coming up on the WW drying towel.
bring out the clay, meguiars red aggressive, last touch/water mix 50/50 for lube, microfiber to remove residue right away.
whole process takes 4.5 hours due to it being EXTREMELY contaminated. I work pretty fast while claying, so its not a speed issue, its a process procedure issue.
what is another way to get rid of all the bonded junk from the paint. I have clayed the same truck before with sonus grey and it took 5 hours with slightly less contamination (I could still see paint last time, not this time).
I use ONR for all my washing, so I dont have a pressure washer setup. I usually work in the direct sun.
What are my options because my arm is killing me, I went through 4.5 hours of claying (too long to spend claying IMO, even though the result are well worth it as it looks 100times better), I used up 1/2 a 200 gram claybar = 15 bucks, and I had to call it quits and do the polishing tomorrow because I ran out of light, my arms are killing me, and my body hungry for energy.
Can I use a decon system in the sun, with onr??? If so, how is it different than washing and claying like I am doing???
