I am not new to detailing. I used to detail for a major car dealership for 2 years a while back and still detail family and friends cars occasionally. I have never used touch up paint on vehicle that had a chip down to the bare, shiny metal. Anyway, I had rocks get kicked up and hit my front left quarter panel. The chips went through all layers of clear coat, color, and primer. I cleaned the are off and degreased it. I had some rustoleum 2 in 1 primer and sprayed it in a container and dabbed some on the spots with a toothpick (Spots are about 2mm x 4mm). That was a pain in the butt because of how small the chips were. I had to keep wiping it off and reapplying it because some would run on to the good paint :angry:.
After getting good coverage with the primer. I let it dry for about 30 minutes and then applied the touch up paint. I let that dry for about 30 minutes to 45 minutes and hit it with hair dryer on hot. Then I applied a clear coat to seal it. This was all done in a 55 - 60 degree temperature. It cooled down over night to about the low 40s and then proceeded to rain. It rained on the fresh touch up job about 4 hours after I completed it. The paint doesn`t looked disturbed but my question is, do you think it was dry enough to keep out moisture when it rained? When I used to detail for mu job, the vehicles were inside afterward so it wasn`t a concern. When I have done this at home in the past the vehicle was in the garage. Well, this time my garage was full from moving so I did this in the driveway. I should have checked the weather for that night. So should it be ok? My concern is if it was not dry enough and moisture crept in it would form rust since the chip was down to the metal. Should I do this over or should it be good to go?
Thanks
Thanks
