Accumulator
Well-known member
Just a reminder to check the pressure and condition of your spare tire from time to time.
I'm pretty good about the cars, but I hadn't done the under-vehicle spare on the Tahoe for a while. After redressing it (just used some old Endurance), I decided to check its pressure and found it had dropped to 34psi, not truly safe for a big SUV, so I pumped it back up.
If your vehicle has a similar setup with the spare underneath, you might also want to make sure the mounting hardware is OK; I keep mine very clean and spray it with https://www.amsoil.com/storefront/amh.aspx every now and then.
If/when you *do* need your spare, it's nice to know you won't have any headaches besides the whole hassle of putting it on. You do have gloves, a dropcloth, etc. right? And if you're running aftermarket wheels you might oughta make sure you have the right lugnuts/bolts for the spare too.
Getting a flat is bad enough without any surprises...
