jrjones60
As an example, let's say that I'm using BlackFire Scratch Resistant Clear Finishing Polish to try to eliminate light to moderate swirls using a LC White foam pad.(trying the least aggressive means first). It's taking care of some of the swirls but not near enough. What if, instead of moving up to BlackFire Scratch Resistant Clear Compound (which is more aggressive) that I just switched over to using the LC Orange foam pad (which has more cutting power than the white pad). Any comments or suggestions? Thanks in advance for your help.
