Cg v34
Street5927
I figured I would take advantage of Autogeeks 20% off + Free Shipping and stock up on some needed items, as well as try some new stuff that I would not normally purchase. I did a search, but came up empty on the CG V34/V36. Anyway, I figured I would try the V34 first, which is a heavier cut compound and if I am satisfied, I may try the V36 as a "down step". Anyway, eventhough I couldn't find anything, has anyone had any experience with the V34/V36?
Just some other things I purchased were new pads, Megs shampoo, Trizac sanding discs, some back up backing plates, and wheel brushes. I also figured I would try the Sonax Wheel Cleaner to see if I will like it.
I've played with V34/V36/V38 at a friend's. It seems to do the job. My friend swears by the Chemical Guys line, and likes the V34/V36/V38 products a lot.
I was able to play with all three. Unfortunately, I don't have any side by side experience with any other products. My understanding of the products is that your usual go-to combination will be V36, then V38. He claims that the V36 is almost an aggressive compound. As for V34, you'd use that for some trashed paint. I don't know if it is me or not, but I feel that V34 dusts quite a bit. It doesn't really bother me because I feel most compounds will dust regardless. If I had a choice, I feel that M105 is a little more solid product. I think the workability is the same, but I feel that you can do a little more correction with M105.
As for V36, I don't really remember much about it. I do know I used it, but nothing about it sticks out for me.
As for V38, the last time I've worked with it, I remember it as having a long working time. I feel that it needs to be worked down quite a bit before you get the desired effect. That and if you don't, it'll be a bit of a pain to wipe off. I don't think you can moderately finish paint with just a few passes of the polisher. I think it needs to be worked all the way down. I've found that if you shortcut, the residue is very tacky.
My thoughts: I dunno. I just feel like there are better products out there. I didn't feel like it was an easy system to work with. Felt that working time was a bit long and I remember doing multiple passes per a stage to get the desired effect. Or maybe I was using the product incorrectly. I was given damp pads, and found that the chemicals don't really like moisture. I did swap out to dry pads and things seemed to work a bit better. The other thing I felt like was that I could have used a different product/system and gotten the same result with less work and in less time. But yeah... that's just me.
As for my friend. He likes it a lot, and he thinks it is much better than the Meguiar's M105/205 combo. Says it's a much better formula with less dusting and better workability. (Also, before I forget, I would tape trim. I think it will discolor trim.) The V chemicals are his go-to products.
Quick Disclaimer: I am not a pro, and my experience with V34/36/38 in maybe once or twice. So... don't give my thoughts too much weight.
Here's a pic of the result of V34/V36/V38 combo. Sorry about the crappy phone pics. It came out really well. Just took forever to get the result.
BTW. Here is a review on Detailing World: Chemical Guys V36 and V34 Testing - Detailing World
Thanks for your response. It is supposed to be water based, which is nice. From your description of longer working times, it sounds much like Optimum Hyper Compound, which I liked with little dusting and longer work times. After I get a chance to play with it, I will post up a review of it.
