Setec Astronomy
Well-known member
Are you using a block to sand?
What would I do? I would do it myself, but that's me.
I’m using a small block to sand the flat areas with distilled water and a few drops of dawn in a spray bottle.Are you using a block to sand?
A real shop would be using a Rotary machines.....Went to my favorite body shop just now. They took a look and said bring it by Monday and they will test out an area free of charge before they do anything.
They said they will do a quick pass with 2000 grit on a DA, smooth with 3000 grit, and possibly do 5000 grit.
They also looked at what I did by hand and milled it; was told the etching seems on the surface and they are very confident. They also said I barely took off any clear with my hand sanding of 3000 grit and I got 90% of it off already.
Will update but the goal is to have the shop sand out the etching if the test looks good on Monday.
If money is no object I would let the body shop do this.Stop being a dick. I’m working on my car and talking to people around here for help and suggestions. Also on this board. I’m not a detailer just a guy trying to enjoy his car.
Anyway I did sand some more and I got most of it out on the trunk lid but it’s taking forever. I def could do it myself but I go meticulously slow and it will take me days with 3000 grit and going section by section.
I do have a question. Is it worth for me to get the body shop to finish this or would I get better results doing this myself? There is no way the shop is going to go slow like me by hand. I literally wet sand and wipe every 2-3 passes and look for the line. As soon as it disappears I stop. They will probably hit it with 2000 grit and pass it over with 3000 and call it good.
It’s not a money thing either it’s what the best results would be. I’ll probably stop by later and talk to them and show my progress.
What would you guys do? My results look good but I’m definately not an expert.
And are you able to Calibrate your PTG??? Who makes it???
How many Microns did you measure On the line, and all around the area, in Microns???
If any shop does not have the most expensive PTG and re-calibrates it every day, before using it, and understands what Microns means, then they are not really that good...
Ok, so they said they would repaint it if they jacked it??? Why would they ever need to say that????
How really good would their "repaint" be??? Did you look at their work????
Stokdgs
Keep in touch ...
Unless you are a very rich person you don't ever want to tell someone this.Yeah I told them I don’t care about the money I just want the best job. I said charge me $1000 I don’t care lol.
He laughed and said it shouldn’t be anywhere near that though.
I'm a broken-record on this, but keep in mind that it's *NOT* about "burning through" the clearcoat. Just thinning the clear too much will result in extreme sensitivity to UV and can result in rapid paint failure. I see so many cars with trashed paint that is obviously the result of over-correcting! You can clearly see how the "Detailers" did the work that caused the damage...damage that didn't show up until long after the work was done, after the cars were in the sun for a while.
I'm glad to see that the shop is taking this concern into consideration when they say that 0.20mils is as far as they want to go. The areas that are only ~4.0mils would already give me pause since the rest of the paint is so much thicker. Hard to say what the explanation might be, but caution is warranted.
Unless the area will not accommodate I always sand with a 6 inch disk. I imagine they'll sand that whole panelThey had to take off 0.2 mils to get rid of it 95%. I took the car back so I can look at their test area for a few days and determine if it’s good for me, I can’t see the line in the sun now but maybe in shadows not sure yet. They said they will do the entire panel because where they sanded all the orange peel is gone and it looks like I have orange peel stripes lol.
The area went from 5.2 to 5 mils. They are telling me they don’t want to go more than that and if I tell them to if they burn through I’d have to pay for a respray. They are comfortable doing only 0.2mils. Also there guage and mine shows the paint thickness to be very un-uniform across the panel. On one panel the paint can vary from a high 4.x to a low 6.x. They said that is also strange and ads to them not wanting to cut more.
Does that sound reasonable?
Other option is I can just get a custom wrap stripes made that are 1mm wider in each side than factory and carry on.
Did they tell you it was 0.2 mils???? Why not just tell you how many microns were removed? Was their PTG able to measure individual layers of material, (paint, primer) ?
Glad it looks better to you... As you carefully move your clean, bare, hand over the area, do you feel Anything at all? Is it just real smooth and flat???
To repair that, you need to take a good polish and a soft pad and carefully level the coating, so you don’t damage the paint. Take your time, checking the surface after each time for an even level. Once level and smooth, apply a new thinner coat, being very cautious around the vinyl not to damage it.
Better to tape the edges. You'll never notice a difference and guaranteed not to burn throughI decided for them just to do the trunk lid so I can see how one whole panel comes out and I can install my spoiler. Dropping it off Monday morning for that, said probably 2 hours of work. They said 2000 grit, 3000, than 5000 followed by a polish. They will hand sand the edges and curves.
Hopefully the whole panel comes out nice and then I’ll schedule the rest. If it doesn’t I’ll probably just stripe the car again and hide it. I’m not willing for them to cut more than 0.2 per discussion with them and others.
