Ceramic Clearcoat - Diamond Cut OK?
gigondaz
Everyone,
On a silver, brand new Merc S-class with ceramic clearcoat, what would be your strategy to buff/compound the ceramic clear to a very high degree of gloss?
Not much problems except for some water-marks on the hood. But I'm aiming for max results.
I was thinking of the following:
1. Megs No85 with W5000 double-sided woolpad - 1st round of cutting.
2. FF106 with Megs Polishing Pad and FLEX.
3. PO85RD fine polishing with Megs Finishing pad + FLEX.
Can Megs 85 be used for compounding ceramic clears, or shd I replace it with Menzerna IP? I only have IP, 106FF and PO85RD. what's your thought, guys???
I haven't worked on Mercedes clear coat, but I wouldn't jump straight from wool+compound to 106FF. I just don't see any need to cut much from a new car anyway. I'd think something like SIP+green or orange, 106FF+black or white, 85RD+black, blue, red would be better and wouldn't introduce so much marring in a brand new finish.
I think in your case I would recommend:
1) M105 Orange/White Lake Country pad (or PFW if you choose)
2) SIP/IP White Lake Country pad
3) PO85RD on Black/Blue
Good cut, brilliant finish, and doesn't require exceptional skill to make it to work. Definitely a good choice for you. :)
