by David W. Bynon
<font size="1">Copyright©, 1999-2002, Autopia Car Care -- All Rights Reserved</font>
A buffer in the hands of a pro can do wonders on a car that has heavy oxidation or minor scratches. Most body shops can use a buffer to blend touch-ups to perfection. Unfortunately, many detail shops and buffer owners don't know how to use the tool, or use the wrong compounds.
Swirls can be removed. However, it will take a fair amount of work on your part. Doing it one small section at a time will allow you to see progress.
If you get swirl marks, most likely the most noticeable area is your hood and trunk sections. To remove these swirl marks, use a product like 3M Perfect-It Swirl Mark Remover or Meguiar's No. 9 Swirl Remover. They both have very mild abrasives. They work slow. They also contain essential oils that will enhance the gloss, detracting from the swirls.
The best tool to apply Swirl Remover is a terry cloth applicator pad (not a terry cloth towel) or a foam applicator. Apply swirl remover by rubbing a generous amount into the paint fore and aft. Do not rub in circles, do not rub side to side, only rub front to rear.
Once the Swirl Remover begins to haze, use a clean terry cloth towel to buff. Again, front to rear only. You will need to do this several times to make an impact. Your hood alone, by hand, may take as long as an hour and a half to two hours. Don't be alarmed by color coming off on your towel. If your car does not have a clear coat, some color will come off on your applicator and towels.
When you're done with the swirl remover (polish), apply your favorite wax. If you can see swirls before you wax, you'll see then after you wax. Wax will not hide imperfections.
<font size="1">All products mentioned in this article are available from Classic Motoring Accessories and are used at the buyer's own risk. Autopia Car Care is not affiliated with and does not represent Classic Motoring Accessories or the manufacturers of the products mentioned. Other fine sources of car care products include Car Care Online, Griot's Garage and Top of the Line.</font>
