Carpet Cleaning - What's in Folex
pingable
What's in Folex that makes it so good ;-)
I'm not a big fan of putting chemicals in like carpet and then not thorougly rinsing them out....but Folex did wonders on areas in my beige interior.
As well, part of my carpet trim is like a velour-tweed type and too much agitation messes up how the grain of the carpet is . I had one slight coffee spill and without a extractor, I just did a pre dwell-wet cloth wipe 2X with Folex and the coffee stain is gone.
I've got my eyes on a extractor but won't settle for a LGCM.....if and when I have the space for a extractor, then will I purchase one.
Just about any aresol window cleaner will eleminate coffee stains on contacts as well. Coffee is probably one of if not the easiest stain to remove effectively. Never heard of Folex but it sounds like it's doing a good job for you.
My experience is mixed with coffee .... if the stain is cleaned in a relatively short amount of time it cleans out easily and completely.
But, if the coffee stain has been allowed to remain for a long time it seems to actually die the fabric or yarn and it is impossible to completely remove .
I hear ya. Actually the stain was there for a week as I did not notice it...
It was sitting in the cupholder, and typical NYC road - bounce bounce made a slight mess in the cupholder-center console . I did not even realize some had spilled down the side of the console onto the carpet.
The carpet was hard and I was afraid it set in too long but lo and behold, it cleaned up relatively clean.
I don't know whats in it that makes it so good but that what I use. I don't have an extractor so I just use elbow grease and Folex and it usually does the job.
What's the process to use for Folex? I had a few set in stains from the kid's juice spills. I sprayed the spots with Folex, let it soak in for a minute or so, scrubbed it with a brush, then soaked it up with a MF Towel. That lightened up the spots, but didn't remove them.
Am I missing a step? Do I need to repeat multiple times? Or are the stains too far gone (it's been a couple of years...didn't notice them because they were under the seat)?
kapinnn said:
I dont think you are supposed to scrub with Folex. Thought it was just blotting.
Removing Carpet Spots
Wow. Thanks for the info. I did read the "agitate with fingers" on the bottle, but I thought I would "kick it up a notch" with the brush. I see the reason not to use the brush is to avoid damaging the carpet fibers. And I do blot at the end.
I'll give it another try using "the right way."
I don't know, but whatever it is, the dash on my BMW didn't like it.
I had an area of a paper towel that I'd used on the carpet and thought I'd just use the other side with my diluted APC for the interior. I think I ended up getting some of the Folex on the dash and the silkscreening or whatever it is on the stalks of my steering wheel (cruise, turn signals) started to smear!
So I'd just make darn sure you only use it on fabric and don't cross contaminate your towels.
MSDS sheet.
CHEMICAL NAME: FOLEX Nonionic
FORMULA: o o o o o o o
CHEMICAL FAMILY: Nonionic Surfactants MOLECULAR WEIGHT: 597, average
TRADE NAME AND SYNONYMS: FOLEX; Instant Carpet Spot Remover
PHYSICAL DATA
APPEARANCE & ODOR: Essentially Pink Liquid; Mild and Odor Free
BOILING POINT: 760mm. Hg. >212° F SOLIDIFICATION TEMP.: 30° F
SPECIFIC GRAVITY: (HC-1) 1.007 @ 20/20°C VAPOR PRESSURE @ 20° C: 1mm.HG
VAPOR DENSITY: (air=1): >1 SOLUBILITY IN WATER: 100% by wt.
PERCENT VOLATILS BY VOLUME: Nil
EVAPORATION RATE: (0.01)
HAZARDOUS INGREDIENTS
FIRE AND EXPLOSION HAZARD DATA
NON FLAMMABLE: No Hazardous Chemicals
HEALTH HAZARD DATA
THRESHOLD LIMIT VALUE: None Established By OSHA
EMERGENCY &
FIRST AID PROCEDURES:
In case of internal consumption drink
four (4) glasses of water in a 30
minute period & seek medical care.
EFFECTS OF OVEREXPOSURE: Nil
REACTIVITY DATA
STABILITY: Stable INCOMPATIBILITY: (Materials to avoid) None
CONDITIONS TO AVOID: None
HAZARDOUS DECOMPOSITION PRODUCTS: None
HAZARDOUS POLYMERIZATION: Will Not Occur
SPILL OR LEAK PROCEDURES
STEPS TO BE TAKEN IF MATERIAL IS RELEASED OR SPILLED: Blot With Absorbent Cloth or Mop
WASTE DISPOSAL METHOD: Bio-Degradable
SPECIAL PROTECTION INFORMATION
RESPIRATORY PROTECTION: None PROTECTIVE GLOVES: None
EYE PROTECTION: None OTHER PROTECTIVE EQUIP: None
VENTILATION: None LOCAL EXHAUST: None
MECHANICAL (GENERAL): Acceptable
SPECIAL PRECAUTIONS
None
Cleaning Fool said:
Butyl is the probobly in Folex. A common chemical used in carpet cleaning. A controversial one as well.
No Butyl in Folex, the MSDS is posted above. As for the effectiveness of Folex, the surfactant they use is probably just more effective than most other carpet cleaners out their. While I do not use Folex, I do use a ph neutral cleaner that contains a naturally derived non-ionic surfactant. It is extremely effective, yet very gently because it contains to organic solvents such as Butyl and is ph neutral. I use this product in my carpet extractor and as a general interior cleaner.
Give it a few more tries. I had the same experience with what I believe was a soda stain. I had to do it a half dozen times. The stain actually got larger and larger the first few times from the agitating, but I knew it was working because the paper towel was always colored every time.
I have not used Folex (on the list to try) but I have used Resolve with very good results.
Folex is a good neutral spotter with a bit of detergent in it. It is not a specific spotter.
If you are looking for an all around kit i strongly suggest following this:
Pretest Spot-Removal Procedures And Products
In an inconspicuous area (under a sofa cushion, on an area of carpet under or behind a piece of furniture), apply several drops of solution on the article and rub gently with a clean, white towel. If color transfers to cloth or a color change occurs a professional cleaner should be consulted. Apply the solution again, wait 1/2 - 1 hour, if possible, and inspect for any damaging color changes.
Do not over wet. Use small amounts of the spotting products and blot frequently. Always blot, do not rub or brush. Work from outer edge of the spot towards the center to prevent rings.
Beginning with step 1, treat the stain area with each spotting solution until the stain is removed. It may not be necessary to complete the entire series of steps. The final step is always to rinse carefully the area with water, then absorb all the remaining moisture with absorbent towels.
Be patient. Some spots respond slowly. All spots and spills cannot be removed from every fabric due to differences in fibers, dyes, construction, finishes, composition of the spills, length of time the spot has remained on the article, etc. Some stains require professional treatment.
To find the right procedure and product for cleaning various stains, choose the type of stain from the list below and select it.
Stain List
Stain Type
Recommended Products
Blood Protein & Stain Spotter, Pro Spotter, Zoop Enzyme Spotter
Butter & Margarine Citrus Gel, Solvent Spotter, Protein Stain Spotter, Pro Spotter, Fiberbuff
Browning (cellulose) Yellow Rx, All Fiber Rinse
Candle Wax Power Solvent, Citrus Gel
Catsup & Tomato Sauce Protein Stain Spotter, Pro Spotter, Zoop Enzyme Spotter, Oxy-Plus
Chewing Gum Citrus Gel
Chocolate Protein Stain Spotter, Pro Spotter, All Fiber Rinse, Zoop Enzyme Spotter
Cocktails Pro Spotter, Coffee & Tannin Spotter, All Fiber Rinse
Coffee Coffee & Tannin Spotter
Cough Syrup Pro Spotter, Zoop Enzyme Spotter, All Fiber Rinse.
Crayons Power Solvent, Citrus Gel
Eggs (Raw) Protein Stain Spotter, Zoop Enzyme Spotter, Pro Spotter
Food Coloring Pro Spotter, Red Rescue
Fruit Juice Pro Spotter, Zoop Enzyme Spotter, Oxy-Plus
Furniture Stain Power Solvent, Citrus Gel, Protein Stain Spotter
Glue (School) Pro Spotter, Protein Stain Spotter
Grass Citrus Gel, Zoop Enzyme Spotter
Gravy Protein Stain Spotter, All Fiber Rinse, Pro Spotter
Greases & Oil Solvent Spotter, Power Solvent, Citrus Gel
Ice Cream Protein & Stain Spotter, All Fiber Rinse, Zoop Enzyme Spotter
Ice Melt Buildup All Fiber Rinse
Ink (Ball Point) Ink Spot Remover, Citrus Gel, Oxy-Plus
Ink (India) Ink Spot Remover, Power Solvent, Citrus Gel
Jam & Jelly Pro Spotter, All Fiber Rinse, Protein Stain Spotter
Lipstick Power Solvent, Citrus Gel, Oxy-Plus, All Fiber Rinse
Mildew Pro Spotter, Zoop Enzyme Spotter, Oxy-Plus
Milk Protein Stain Spotter, All Fiber Rinse, Zoop Enzyme Spotter
Mucilage (Glue) Pro Spotter, Zoop Enzyme Spotter, Protein Stain Spotter
Mud Pro Spotter, Citrus Gel
Mustard Protein Stain Spotter, All Fiber Rinse, Pro Spotter, Zoop Enzyme Spotter
Nail Polish Power Solvent, Citrus Gel, All Fiber Rinse
Oils Power Solvent, Citrus Gel, Pro Spotter, All Fiber Rinse
Paint (Oil) Power Solvent, Citrus Gel, Pro Spotter
Paint (Water, Latex base) Pro Spotter, Solvent Spotter, Citrus Gel
Rubber Cement Power Solvent, Citrus Gel
Rust Prochem Rust Remover
Shoe Polish Power Solvent, Citrus Gel
Soft Drinks Pro Spotter, All Fiber Rinse
Soot Citrus Gel, Olefin Preconditioner
Tar & Asphalt Power Solvent or Solvent Spotter, Citrus Gel
Toothpaste Pro Spotter, All Fiber Rinse
Urine Pet Spotter & Deodorizer, All Fiber Rinse
Vomit Pro Spotter, Zoop Enzyme Spotter, All Fiber Rinse
Wine Pro Spotter, All Fiber Rinse
Yellowing Yellow Rx, All Fiber Rinse
Traffic Lanes Ultrapac Trafficlean or Ultrapac Trafficlean Mint Fresh, All Fiber Rinse, Dry Slurry, Clean Green
Soil Filtration Lines Filter-Out, All Fiber Rinse, Dry Slurry, Oxy-Plus
As for a spotting kit prochem spotting kit k250
I would then add Red- relief, and Stain magic from Pro's choice for red and orange dyes depending on if they are natural or synthetic food grade dyes. For yellow staining I use pro's choice urine stain remover.
Home
I would also strongly recommend bi-0-kleen traffic lane cleaner and back out.
We are the Environment | Biokleen
Pro-chem is a large carpet, uphostery, leather, tile etc company.
Prochem - Chemicals, Cleaning Machines and Truck Mounts
For general soils, oils and grime i use prochem ultra-pac LVC for carpets and uphostery in cars, trucks and Suv's. I then filter down to prochems spotters as needed.
For vehicles with mostly food grime IE kids, dogs, Etc I move over to bi-o-kleen's traffic lane cleaner as my preconditioner. I still pre spot most everything with prochem spotters.
The recent flood of interior data has me interested. I feel I have been missing out on conducting over-kill on this, the place where people spend 100% of their time in the car. My customers all have food stains and odors, I use Bio-Kleen now.
AARON - I am purchasing the Prochem -K250 on Monday. (what does it cost?) Would I utilize this chemicals in this kit, then focus my extraction at the tail end of spotting and cleaning to draw out all of the debris and excess chemical remnants?
Would I extract with only water or are additives necessary, dry slurry, ect?
even the good quality brand of apc i use isnt steering wheel stalk friendly even at 20:1.
im sure the folex didnt help, but the white ink on those things comes off pretty easily especially after theyve seen some sun. i use a different mf towel sprayed with onr specifically for wiping the stalks and for an initial wiping of the speedo and center gauges and navi screen.
even m40 has given me slight smearing problems on older cars.. its just all the cleaning agents doing their job.
