Using an orbital buffer (with a brush attachment):
Methodology
â€Â¢Vacuum area very thoroughly to remove any loose dirt, grit and etc
â€Â¢Remove any stains with 303â„¢ Spot Remover & Cleaner
â€Â¢Spot treat really bad stains (303TM Cleaner & Spot Remover or Woolite® Heavy Traffic Carpet Foam)
â€Â¢Use a pre-cleaner solution, 10:1 distilled hot water/ P21S Total Auto Wash, let solution dwell for 5-10 minutes to enable cleaners to react
â€Â¢Agitate surfaces with an random orbital buffer (speed #4) and brush attachment, scrub carpet / fabric upholstery
â€Â¢Mist spray surfaces with hot water
â€Â¢Attach a terry-cloth bonnet and go over areas, changing the bonnets frequently
â€Â¢Use a rubber bristle brush go over the material to raise the fibres
â€Â¢Using the vacuum, remove the excess moisture, loose dirt and the grim
â€Â¢Allow carpets / mats to thoroughly dry before use
â€Â¢Once fabric is dry apply a fabric protection (303TM High Tech Fabric Guard)
Note: Use the hottest water available it also helps to pre-spray the carpet with hot water when hand cleaning carpets / mats
JonM
