1vh1 said:
First, I'm using a PC747X(?) I forget the exact code, but it is a dual action polisher..I went out and wiped down the car with some 425 and probably 70% of the holograms "shifted" to the way I wiped them. I am guessing these are those bonding issues you guys suggested. The other 30% are most likely from using the wrong pad/polish combo..
Ah, that clarifies things quite a bit.
I was using CCS line pads for clarification...
Are those the (boo hiss) "dimpled" pads?
I guess I will have to start from step one to get rid of [the issues that aren't just LSP/oils related]...
Maybe, but probably "not quite". I wouldn't go all the way back to the M105/orange, but rather M105 on a milder polishing pad. And be *especially* careful/gentle about two things: 1) keep the pads (plural
) *VERY* clean, no clumps of product or buildup of cut-off paint...clean 'em way more often than you think you oughta, and also 2) spritz some "clean" QD like Meguiar's M34 (*NO* don't use a leaves-stuff-behind QD like FK425!) on before you buff off the M105 residue and still be as gentle as possible while buffing it off. Remember that the M15 will *always* cut; it doesn't break down, it doesn't go away, it just sits there waiting to cut the paint some more...like when you buff it off.
Then do the M205/orange and follow up with something even milder. But stick with the M205/orange until all the issues are gone.
AND, find some way to remove all those TSOs that the M205 leaves behind. I use TOL/Hi-Temp's Akra Clean (AKA PrepWash). As I posted before, I find IPA to be pretty lousy for this, so whatever you do expect to work at it a bit. This is the big reason why I no longer like/recommend M205, it's just such a PIA!
What can I do to get rid those bonding holograms though? They were stubborn to my FK425 and cobra microfibre.
The real solution is to eliminate the bonding problems. Get rid of those TSOs after you've finished with the M205 to provide a "clean" surface and to take them out of the equation. If you want to do the SRP, that oughta be OK and shouldn't contribute to any problems. Then, if you want to use both FK1000P and something else, use the FK first and let it cure for a while before you top it. Yeah, I know...(anticipating
Ron Ketcham's input
) you're not supposed to *need* to let it cure for long, but it always seems to head off problems for me. As long as there are bonding issues, well....you're gonna have appearance issues too
So don't try to top the Natty's with the FK...you've already learned that approach doesn't work for you.
I really like the look of the Natty's blue paste "wax" on my blue metallic paint. It makes the flake pop like none of the other waxes/ sealants I have (1000p, Autogylm HD, SRP.) I just don't like how it sheets. I can't "dust" the car by sheeting water on it. That's why I topped it with 1000p that stuff sheets like crazy.
The final look oughta be mostly a matter of whatever you use last, so you'll "see" the Natty's if you use that last. But this "sheeting" thing throws a whole 'nother factor into the mix :think: I think I'd try to find a leaves-stuff-behind QD or (much better) a spray wax that a) doesn't mess with the look you like and b) behaves the way you want with regard to the sheeting.
EDIT: Oh, and be a little careful about using FK425. Yeah, I really *REALLY* like it, but sometimes it has messed up my LSP, giving those same "pseudo-holograms". Had it happen when I used FK425 over top of Collinite..made a royal mess out of the dark blue Audi (back when it still belonged to its original owner).
