Can you use EX-P and Natty's Blue Interchangeably??
I may be going out on a limb here but I believe that the rule of thumb is wax over sealant but not a sealant over wax.
So once you top a sealant with a carnuaba you must remove the carnuaba with a polish before applying a sealant. Sometimes one can use a wash to remove products or even a 50/50 ISA wipedown or both. I prefer a polish. Others do not. That is to let the sealant bond to the clean surface of the paint rather than trying to bond to a carnuaba.
That is how I do it for all of my vehicles.
Yup cwcad is spot on. The process should be sealant and then carnauba paste wax. Make sure you let the sealant cure 24 hours before applying the wax. If you want more protection, do 2 layers of sealant 24 hours apart and then keep adding up the natty's whenever you want after that.
