Jul 4, 2007 #1 P pak-man New member Hey anybody know if you can use CG's MF Rejuvenator solution to clean foam pads?
Jul 4, 2007 #2 Old Pirate AMG Classic Car Detailing I haven't use it, because i use dawn power dissolver and it works very good on cleaning my pads and costs about 2.25.
Jul 4, 2007 #5 A Accumulator Well-known member I've used MF detergents, including the CG's one, and they work fine for this.
Jul 4, 2007 #6 P pak-man New member I haven't used the Dawn Power Dissolver before. Do I just spray till its soaked and then rinse it or do I dunk it in water with it. What's the process?
Jul 4, 2007 #7 S stiffdogg06 New member I usually get the pad wet with warm water. Then, put a swirl or X; whatever you prefer on the pad. I then work the dawn into the pad with a little bit of water. And then rinse clean.
