Can this work?
Go getta
What up fellas? Ok.. First off I'm working from my cell right now and unable to upload photo. But I'm very curious to know how this can work, I just got my hands on a 55 gallon plastic drum completely sealed. I read recently where someone mentioned this type of drum possibly being used as a water source. My ? Is will this work, if so how, if not why?
At the top of from there are two hOles sealed by plastic stoppers how and will this affect the setup, benefit/drawback?
Google "rain barrel" for instructions on how to put a hose fitting on side or bottom. Flow will be weak unless you're using it to feed a pressure washer, and then 55gal won't last long. Understand most mobile tanks are a couple hundred gallons.
One hole or vent is necessary for water to flow. If air doesn't replace the water you draw out, you quickly create a vacuum and not the good kind.
Thanks for the reply my man, about to check it out now. as far as the set up goes, i have a pw to do all the washing/rinsing etc. Im currently running a 180g tank on my trailer which is almost always set up @ one location. However, i just got my hands on an astro cargo van which will be used strictly for details, im thinking 55g should get me through a single day, but what do you think?
Hey man i just finished checking out these "rain barrels" THIS IS GONNA WORK... I'm actually headed to Lowes right now to get everything else. Thanks Mderleth
I have a 90 gallon tank and can make it through at least 4 car washes/shampoos with 90 gallons. The guy who trained me at Rightlook, used 90 gallons for a full days work....
