imported_Indy YZF
The other day, I drove up to Bristol to keep my dyno appt. It was forecast to get all the way to 40 degrees, so I figured Id better do it then, as the next two wks are supposed to be well below freezing. When I got there, though, the pipes had burst, and the rollers were under 3ft of water. No dynoing that day, thats for sure. On the way back, the snow let loose like you wouldnt believe. But all the sand and salt on the roads just turned it into a muddy slop, and the car was disgustingly dirty.
The next day, Wed, I decided Id better get it washed. So I went to my local Splash carwash, and told them not to use the towels; I didnt want them putting any scratches in the clearcoat.
When I got home and took a good look under the lights, to my horror, there were dozens of the strangest looking clearcoat layer scratches all over my hood of my white Dinan supercharged '99 M3 Ive ever seen.. They were unusually shiny, and had these strange curves and jaggy shapes in them, and were from 2" to a ft in length running generally from the front to the back of the hood.. I Always polish the surface scratches out of the car, as I cant stand swirls and scratches, and I know the surface like the back of my hand. These definitely came from the carwash. I thought that because the water was hot, Id be ok. It was 9 degrees out at the time of my carwash, and knowing the scratches came from the agitated vertical strips of material they use to 'clean' the horizontal surfaces, I wasnt sure whether it came from inbedded dirt and grit, or from ice on the material. The strips of material looked very clean to me, and usually, Ive found if I can keep the guys from towel drying it, Im ok because the strips have never done this before. So Im guessing its ice on the strips.
But, I really didnt think Ice could scratch paint. But, I guess if its so cold that the water droplets on the car froze solid instantly as soon as I rolled the car out of the wash bay, that it really could do the scratching. The unusual appearance of the scratches led me to believe this was indeed what had happened. So, I must have looked like an idiot to the other tenants in my condo, as I spent the next 3 hrs in our communal garage with my rotary drill, and foam bonnets with various polish compounds , removing the damage.
So, dirty as your car may be, wait til ice is no longer forming. It doesnt have to be above freezing, as the hot water will keep ice off the equipment UNLESS it gets down below 20 degrees. And, below 10, like with me, nothing will keep the ice away!
