Cam Spray 1500A - 1450 PSI Cold Water Electric Hand Carry Pressure Washer
used for about 1 year, new working condition, looking for $500 located in Kingston,ON. [email protected]
specs
Designed with a powder-coated skid, this hand carry pressure washer is great for every job around the house including cleaning your driveway, deck, and automobile. It features a 35 foot power cord with ground fault interrupter which provides a safe environment when cleaning tough dirt and grime. This pressure washer also comes with a trigger gun and a 25 foot non-marking pressure hose, making it the complete package for all your cleaning needs.
Features:
* Triplex plunger pump with ceramic plungers and stainless steel valves
* 35' Power cord with ground fault interrupter
* Adjustable pressure
* Thermal relief valve
* Powder-coated skid
* Mechanical thermal relief valve
* Trigger gun
* 36" Two piece wand
* Multi-reg zero to sixty degree pattern tip with hi-low for chemical injection
* Non-marking hose
Specifications:
* Maximum PSI: 1450 PSI
* Adjustable pressure: 100 PSI/1450 PSI
* Engine: 2.0 HP
* Volts: 120 volt / 20 amp
* Phase: single
* Thermal relief: mechanical
* Maximum pump temperature: 140 degrees fahrenheit
* Water flow: 2.0 GPM / 7.6 Ipm
* Water temperature: cold water
* Chemical injection: yes
* Hose: 26 feet
* Nozzle: multi-reg 0-60 degree pattern tip
* Dimensions: 11 H X 12 W X 18 D
specs
Features:
* Trigger gun
* Non-marking hose
Specifications:
* Engine: 2.0 HP
* Phase: single
* Hose: 26 feet
