Callaway X-24 HOT Irons is the longest and most accurate irons the Callaway company has ever made. It is skills enhancement than callaway x22. Callaway designed the faces of the X-24 Hot to progress from thick on the bottom to thin along the topline, like previous X Series irons. Callaway engineers strengthened loft in the long and mid-irons (the PW is the same as in x22 irons), increased shaft length by 0.25 inches per club (compared to the x22), and redesigned the head to account for new weight distribution. callaway x24 progressiveness is mainly reflected in some aspects, like VFT, accurate.
For Callaway X-22 Irons, notch weight of the new design, the weight is transferred to the position for optimum performance, 10% higher in subsection irons moment of inertia of previous similar irons, to maintain the original center of gravity position in order to create the trajectory and distance control. The streamlined head shape with a slightly thinner top line of the blade and bottom of the sweet spot of a large area in order to increase the beauty and fault tolerance, and enhance the golfer's confidence. Modified Tru-Bore design is also used in subsection irons, reducing vibration, increasing the feel.
