Accumulator said:On Audis, I like 1Z High Gloss and/or 1Z Pro MP (both via Cyclo with finishing pads, used after all correction has been finished). On the DenaliXL, I used 1Z WaxPolish Soft, also by Cyclo.
Yeah, I use *very* little product, just enough to keep the pads lubricated. I work the 1Z HG until it basically disappears (no micromarring from the residue IME).
On softer paint, I'd probably go with Menzerna FPII.
jooccord said:Another quick question. Is there a big difference Burnishing on a DA(or cyclo) and Burnishing with a Rotary?
loudog2 said:Got my vote for 85RD w/LC blue pad.
themightytimmah said:I love 3M's Ultrafina via rotary and blue pad for burnishing. Heat it up to 1800rpms for maximum gloss then drop it down to 1200 to ensure a hologram-free finish. It gives a super wet look, but it can hide marring if the paint is not properly finished beforehand.
(Right of wheel flare is burnished, left is not)
Flashtime said:Burnishing: Burnishing (metalworking - Wikipedia, the free encyclopedia)
Plastic deformation: Deformation (engineering - Wikipedia, the free encyclopedia)
Legacy99 said:85rd is used by many for jeweling, however, if you final polish a lot and don't want to degrade your cc, you should look into 87MC. 85rd has a cut of 1.5 and 87mc has a cut of only 1, which makes it perfect for correcting light marring and still burnish your paint. I take great pains in keeping my paint swril free and usually only need a paint cleaner when resealing or rewaxing. When I need to polish I use 87mc which has the least cut of the Menz line of polishes. BTW 87mc is the same as Final Polish II :buffing:
EisenHulk said:Just to add a little more confusion to what Legacy99 said, 87MC/FP II is also known as Micro Polish. It's actually labeled as Micro Polish on the bottle...at least it is on the bottle I have.
In case you're wondering why 85RD has more cut than 87MC, it's because 85RD is rated for ceramiclear paint.
EisenHulk said:Hey, Supe. I got my bottle from The Geek. It was one of the first products I ordered when I started detailing.
I still have the PM you responded to that breaks down the Menz classification system. It was so damn confusing when I started out. Thanks again!!!
By the way, I could smell the sarcasm in your final sentence. Haha.
loudog2 said:Which pad do you use? Blue or grey?
loudog2 said:Thanks! just curious, since I've never used the 87MC before.
