Dellinger
So, to refresh the members here... I'm a noob.
Anyway, back for more!
I need some recommendations on some utensils... mainly brushes: inside, outside, wheels, and anywhere else that they may be of value. I understand that the boar's hair are the most desirable most likely because they are less scratch prone?
Secondly... Trim (maybe it is, maybe not)... you know on some 4 door cars there is usually a black painted vertical piece (either metal/plastic) with a satin or glossy black, usually located to the left of where the window seals against. Do you gentlemen polish these as well (as in with a paint polish like 205)? My gut says ''No" because it would seem that the paint layer is fairly thin (if metal) and if I'm correct what product do you use to remove oxidation? Is there a dedicated 'trim compound' for plastic and the small black metal surfaces? I've read about the Black Wow and such but not sure this is the product I need for what I'm describing.
Wax- I've always wondered when I see it offered by the gallon, what products detailer's prefer in this size? This is nothing more than me being bored at night wondering but if you care to indulge me, I would appreciate it. There are some pretty good deals to be had in this size (CG Butter Wax, Megs X-press Wax, etc...)
Regards,
-Dellinger
Regards,
-Dellinger
